Worn out '85 IROC?
Old Jun 14, 2006 | 02:11 AM
afr5's Avatar
Worn out '85 IROC?
I was wondering what I should do to help bring back some spunk into my IROC. It has 150,000 miles (although high, i'm not sure if thats the average mileage most people have for a 21 year old car).
I'd like to do all the bushings, drivetrain/powertrain mounts, subframe connectors, etc..
Does anybody have any suggestions?
I found no sticky or relevant thread on this topic.
Old Jun 14, 2006 | 03:04 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
sway bar link bushing runs for like 20bux in local autozone.
as far as i know, thats one of the easiest bushing to replace.
I'd start from there.. and maybe control arm bushing etc etc if u know how(caz i dont
Old Jun 14, 2006 | 05:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Decide what you want the car to be: a comfortable riding daily driver, a canyon carver, or a strip car and "plan" accordingly. In any case, SFC's are a must.
JamesC
Old Jun 14, 2006 | 09:25 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
A strut/shock tower brace also helps a bunch.
Old Jun 14, 2006 | 09:53 AM
JamesC's Avatar
Here's what I did to canyon carve and to keep the 'sleeper' look (maybe provide you with some ideas about which direction you'd like to go):
350 HO Deluxe (350ci/330hp), GM lightweight flywheel, CenterForce II clutch kit, Hooker headers, Catco hi-flow cat, Hooker cat-back with OEM tail pipes, GM dual electric fans, OEM T5 with B&M Ripper short-throw and Hammer shifter, Energy Suspension motor, tranny, secondary crossmember, torque arm, bump stops, and tie-rod boots, Prothane A-arm bushings, Global West steering box brace and subframe connectors, Hotchkis tie-rod sleeves, Spohn 1LE front brake kit, PBR rears, Earl's braided-steel brake lines, 1LE sway bars with GM poly end links and Top-Down Solutions greaseable 36mm front and Energy Suspension greaseable 24mm rear bushings, 1LE aluminum drive shaft, Edelbrock torque arm, Spohn lower control arms and panhard, Summit differential cover, OEM 10-bolt with limited slip and 3.23’s.
Some other stuff: aluminum space-saver spare. Lear/Seigler Conteur driver’s seat, overhead console, 145 mph speedo and 5500 red-line tach, MBA billet pedals, Alpine CD player and Kenwood speakers, Grant Signature Series steering wheel with black billet sleeve and silver 'Camaro' horn button, and **** mirror (auto dimming, temp, compass). Sylvania Silverstars. Propart clear side markers.
Future: Spohn tubular a-arms, new OEM springs, Koni reds all around, spherical strut towers, and eventually a STB (for carbed cars with A/C on the driver's side)
JamesC
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
mustangman65_79
Aug 11, 2015 03:17 PM
