New wheels
Old Jun 1, 2006 | 10:25 PM
BanditMan's Avatar
Car: 84 trans am
Engine: 305 H.O. with small cam
Transmission: th350 with manual valvebody
Axle/Gears: 3:73's
New wheels
I had a post a while ago about what the biggest tires that i could tuck under the back of my 84 ta were.Well ive searched different sites for nice wheels at good prices, and tires for good prices. Well, i think i found what i want at summit, as im on a budget.They are 15x7 cragar flash wheels with 4 inch backspace.I couldnt find what i wanted in an 8 icnh wide rim, but 7 should be fine. The tires i have found are yokohama avid st's in 235/70/15, which is 28 inch tall, just whati need as im tryin to get my revs down a bit.But my question is with the 235/70/15 on that 15x7 rims with 4 inch backspace rub? I wanted a 15x8 with 275/60/15 but i could find a rim i liked at a good price with the right backspace.I know some of you are thinking, yeesh, a tall sidewall narrow tire, well im not worried about handling that much, just a good daily driver.So will this fit without rubbing?
Old Jun 6, 2006 | 11:54 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
come on yall help me out here. Also what would be a good tire for the front thats also on a 15x7. I really need this info guys and gals.
Old Jun 7, 2006 | 01:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
235/60R15 is good on the front, on 15x7 wheels
i'm not sure about your backspacing issue, I have 15x8 with 275/60's on the rear, and no idea what the backspacing is....
Old Jun 12, 2006 | 01:32 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
I am thining of going to a American RAcing TT2. I wanna go 17X8.5 front and 17X9 in back. Will those wheels fit? Tire size will be a 245/im thinking 50/17
Old Jun 12, 2006 | 02:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Most people go with the 17 x 9.5's with 275/40/17 tires. They will fit without an issue all around. Thats what I plan on getting but in the TT2 Classic series with the dark center.
Old Jun 13, 2006 | 06:03 PM
Car: 1991 Camaro RS
Woah, I ment 9.5. And ya, the 40. I couldnt remember what it was. But like I said, I am gunna go 8 in the front but with the same tire size as well. You say they will fit on at no problem, so you dont need any kind of spacers or anything?
Old Jun 13, 2006 | 07:23 PM
Shagwell's Avatar
Car: projects.......
XxGeinNothingxX - If you're gonna run the same size tire front and rear, run the same size wheel.
- lets not steal someone elses's thread here guys.....
BanditMan - Why not just go ahead and run the 235/60 on the 15x7? They'll tuck a little, but not bad. I think a 235/70 would look to much like a truck tire....
Old Jun 13, 2006 | 11:21 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
thanks shagwell. I wanted the 70 for the rollout, cuz i have 3.73's in the back with a turbo 350, and with 24 inch tires that i have ow, i turn around 2700 at 55= bad gas mileage, really bad,lol.Wht do you mean it will tuck a little?will it fit? How tall is the 235/60? I would like to keep the look i have of my rims and tires, beacuse they poke out a lil and have that nice aggressive wide stance, but then id have to dive into the axle, i dont really wanna do that. Thanks yall.
Old Jun 14, 2006 | 12:23 PM
Shagwell's Avatar
235/60 is about 26" tall. tuck = bubble slightly, because of the wheel being a bit skinnier than the tread width. I think you 235/70 idea should fit, as long as your springs aren't to worn out. 15x7 with a 4" bs probably isn't gonna stick out much if any. - I understand getting your r's down, I would just run a little wider. 255/70 maybe..... That way it'd atleast look more like a car tire. - I've seen 275/60 on the factory 15x7's. 7" is a bit skinny for them, but if you keep after the air pressure they'd probably wear fine.- they're right around 28 tall...
Old Jun 14, 2006 | 12:43 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
so I could run the 275/60 on the 7 inch rim, and it wouldnt rub?
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
