Severe Drop...What size tires?
Old Jun 17, 2006 | 09:36 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
I've got an '87 SC with dropzone springs and it's very low in the front. I'm getting ready to put my 16" irocs on. What size tire should I use for the least amount of rubbing? Would the stock size for this wheel be ok?
Old Jun 17, 2006 | 10:14 AM
back in black's Avatar
Car: 86 Iroc
Engine: 305 tpi lightly modified
Axle/Gears: 4 10's
I'm in the process of putting 18" iroc's on mine and am going with a 245 width but was also told I could go to a 255 by many with no rubbing issues what so ever.
Old Jun 17, 2006 | 11:14 AM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
24 3/4" fender height on 245/50-16 tires and 16" IROC's. This car is a lightweight nosed V6 (so less bounce inertia from less engine weight) and the suspension is very very stiff with 800lb springs and Koni Yellows so it does not rub- Car only has a front suspension travel of 1" normal and 1 1/2" in the most severe case. If you have more travel than this- which you most likely will have double, you will be grounding out and the tire will hit the top of the fender well.
ps- you have to be hitting with the tires yoiu have right now on large bumps.
Old Jun 17, 2006 | 04:26 PM
Car: '87 Camaro SC
Engine: 305 LG4
My fender height is 24 3/4" too, but I'm hoping it will come up just a little with some new struts. I guess I will go with the 245/50-16. Thanks for the help!
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
