torque arm
Old Jun 17, 2006 | 10:22 PM
camaroman350's Avatar
Car: 92 Camaro RS
torque arm
my torque arm mount broke on my car and the springs squeek reel loud. when i bolt the torque arm back up will it eliminate the squeek? + could it have damaged any other suspension componets
Old Jun 18, 2006 | 05:51 PM
Pocket's Avatar
Car: 91 Trans Am
So your torque arm is just floppin free?
That just sounds dangerous never mind a squeak, be in a sticky situation if your TQarm touches the ground when your moving forward...
Basically the torque arm controls the angle of your rear end, you need this part or another to replace it i.e. 4 link etc
Id fix it before you go squeak hunting
Squeaks are likely the rubber insulator ontop of the springs
Way to fix this is remove it and coat it with grease or some other lubricant that doesnt wash right off like motor oil
Old Jun 19, 2006 | 03:40 AM
CrazyHawaiian's Avatar
Car: too many ...
I don't know what the effects would be while driving, but with the way the torque arm is designed it will want to go up towards the trans tunnel if it were disconnected, not down towards the ground. But hey who knows, in any event its not good. New torque arm bushing is cheap but be aware there were three different types of torque arm brackets used on our cars, I would remove the clamshell bracket and take it with you when you go to buy the bushing to make sure you get one that will fit. Not sure about the squeek, could be anything. Replace the known bad part and go from there.
Old Jun 19, 2006 | 12:12 PM
Shagwell's Avatar
Car: projects.......
...hey crazy, ever step on the brakes? When you do, the rear tries to twist downward, thus the tq arm heads for the pavement. I hope this guy doesn't live around me, I like my vehicles the way they are......
Old Jun 19, 2006 | 05:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like a pole vault waiting to happen! I always wondered how everyone gets their cars upside down on the side of the highway with no other cars involved! Get that mount fixed before driving anymore!
Old Jun 19, 2006 | 08:55 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
It is not a pretty sight. I had mine break on the 3-4 shift. What originally sounded & felt like the drive shaft, turned out to be the torque arm. It came up & hit the tunnel & when I let off it tried to drop, only to be stopped by the limit of the driveshaft/u-joint movement combined with the driveshaft loop. This was enough to rip the rear brake hose off, making the stop from 100+ even worse as I could not slow it by downshifting.
Check it out ASAP, it can kill you.
Lonnie
Old Jun 20, 2006 | 03:24 AM
Car: too many ...
I've never driven a car with the torque arm disconnected, thats why I said I don't know what the effects would be while driving. My only experience with the torque arm disconnected is when its on jackstands and I'm working on it. I dunno what would happen but I agree its not safe, not a good idea to continue driving the car with the thing disconnected.
Old Jun 20, 2006 | 12:21 PM
Shagwell's Avatar
...that's because you have the common sense to know better...
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
