Tire Size
Old Jun 13, 2006 | 05:17 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Tire Size
What the biggest tire you can run on an 8 inch rim? I bought some 18X8's and need to know what size tire would fill up the rear wheel well. The car is stock height.
Would a 245/40/18 be good for the front?
Old Jun 13, 2006 | 06:39 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
23 views and no one can answer. I know there's someone out there that knows.
Old Jun 13, 2006 | 07:02 PM
'86 350's Avatar
Car: '86 Camaro SC
Well technically you can go pretty damn big on an 8" rim. I've seen people run 275's on 7" rims, so I don't see 295's or 315's being exactly out of reach for an 8". Granted that would only be good for striaght line, horrible for handling.
On my 17 x 8 Snypers I run a 245/45/17 up front. 245 and maybe 255 seems to be a good, popular size for an 8" rim.
Old Jun 13, 2006 | 07:09 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
255's will fit well.
Old Jun 13, 2006 | 07:43 PM
fmacon1992's Avatar
Car: 1992 RS
I would go with 255/40
Old Jun 13, 2006 | 10:09 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I would not go with a 255/40 i would stay with a 245/45 on a 8" rim. Why? Because thats what i choose for my 8" snypers and i dont like how it looks. Its too skinny and thats cause it is, at only 25" tall...stock size is 25.7" tall.
I have a 9" rim on the back being a 285/40 and thats 26" tall and its huge and it doesnt handle well. I screwed up tire sizes on both rims.
Fit the tire to the rim.
Old Jun 13, 2006 | 10:16 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
ahaha 295s are you serious...there is a point where it becomes impossible...i work at discount tire co and i mounted 275 40 18s for my older brother on 18x8 inch wide wheels and it was A BIATCH...he DEF couldnt go any wider...it would tear the bead...it took four guys including myself to get those 275s on
DO NOT try to go any bigger than a 275 or youll be paying BIG bucks to get them mounted...it took nearly 45 min to get the 275s mounted and aired up...bc getting the bead to seat is a entire new story of annoyance
stick with 255 to 265 at the abs max...it you want over 285 get atleast a 9" wide rim...better if its 10"
btw here is the most common and BEST recommendation for doing what you want...go 245 40 18 up front and 275 35 18 out back...it will work and they are nearly identical in every way except sidewall height to the stock setup
almost identical diameter and everything...have fun getting those 275s on tho
Last edited by GodSpeedGTA; Jun 13, 2006 at 10:18 PM. Reason: Automerged Doublepost
Old Jun 13, 2006 | 10:22 PM
Stevo's Avatar
lol that does sound pretty dumb...it was hard by myself mounting all 4 of my OVERSIZED tires...2 pry bars and lots of words from my mouth and its done. Whats funny is that the shop i was using there machine at just got a new one with the arm to push down on the other side of the tire for ya. Makes changing any tires a PIECE OF CAKE.
Old Jun 13, 2006 | 11:40 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I say get rid of the 18x8's and go 18x9.5 all 4 corners like I did with 275/35/18front and 285/35/18rear. Or go with 18x9 or 9.5 front and 18x10rear.
Old Jun 13, 2006 | 11:57 PM
Car: 1989 GTA
yeah we had to use 4 pry bars to get my bros 275s on it was ridiculous...and then we had to get a big fat dude to bounce on the tire until it finally began seating...it was ridiculous...god i hope he nv has a flat
however i should mention he had runflat tires...which was most of the reason for their stubborness to seat but it would still be difficult to mount them if theyre not run flats
Old Jun 14, 2006 | 01:12 AM
Red92RS's Avatar
Car: 1992 Camaro RS
I would not put anything bigger than a 255 tire because the side wall should sit flat like this " |_|" and any wider would sit like this " /__\ " , If you put on a bigger tire than the rim requires you put alot more stress on the sidewalls of the tires and this can become dangerous at low pressures( If you happen to puncture tire with nail etc.) which will be more likely to damage the tire. If any company is willing to mount a tire too wide for the rim than they are more than likely not following the manufacturers recommendations(which are pretty strict with most national brands), and just want to make more money selling a more expensive tire.
Old Jun 14, 2006 | 10:07 AM
Car: 1989 GTA
technically thats not all true...why do tahoes and trucks come with 265 70 16 tires on 7" wide rims...the tires do sit like you say however its not "dangerous" unless you like driving on flat tires...the reason thats somewhat dangerous (in which case it would be NO MATTER HOW straight the sidewall sits) is because if it goes flat and you drive on it it will basically ride on the rim with the tire wedged btw it and the road and rub the sidewall so thin that it will just shread to pieces...ive seen it a thousand times...its call run flat or a run flat ring...it basically burns a ring around the inside sidewall of the tire and DOES RUIN THE TIRE IF IT doesnt blow it out...but thats because some people dont look at their tires before they go somewhere...or cant notice when they look low...i mean how hard is it to tell?
i dont know about all tire shops, but at Discount Tire we dont sell anything that we know is gonna be a problem...bc it if is a problem then its our asses...we test fit everything we put on, refuse to work on anything w/spacers, and if something rubs or doesnt work we tell the customer what needs to be done to fix it or go to a smaller size
Old Jun 14, 2006 | 12:08 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
its easier to fit a wider tire on a narrower rim when you have a bigger sidewall. like putting a 275/60/15 on a 15x7 isnt that hard, compared to putting a 275 on an 18x7, forget about it.
Old Jun 14, 2006 | 01:42 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I know the guys at the shop had a hell of a time putting my 275/40's onto a 17x10 rim..
Old Jun 14, 2006 | 03:11 PM
'86 350's Avatar
Car: '86 Camaro SC
Yeah, actually I'm dead serious. It's gonna be different on an 18" rim, but that don't mean ****. We had a guy come into our shop wanting to mount some ET streets to a 15 x 7 rim. The streets were 275/60/15 I believe. They went on fine. They were wide for sure, but for striaght line, they work absolutely fine.
On my 17 x 9 rims, I didn't find it all that hard to mount 275's on either.....
Old Jun 14, 2006 | 03:36 PM
Stevo's Avatar
Yes that also i forgot to add. Smaller sidewall obviously are harder to get on no matter what the size. The 60 series tires are not hard to get on no matter the size really. We should be talking about 30 and 40 series tires here.
Old Jun 14, 2006 | 04:49 PM
back in black's Avatar
Car: 86 Iroc
Engine: 305 tpi lightly modified
Axle/Gears: 4 10's
Now that were on the topic I'm having a heck of a time deciding the following.Currently I have 245/50-16 on my 86 iroc rims.Pretty tall side wall(I think)I just ordered replica 18"x8 Irocs and am waffling between 245/40-245-35 or 255/40 or 255/35.I want to stay the same size on all 4.I'm thinkin the 35's will make it look like there's too much rim and not enough tire,so I'm leaning to the 45 but not sure on the 245 or 255(I know alot of this is personal prefence look as well.I also live in a small town with alot of little pot holes>whatcha think!
Old Jun 14, 2006 | 08:30 PM
Car: 1989 GTA
o so that dont mean **** when your mounting 295 35 18 on a 7" wide rim??? ...were not talking a 60 ratio here as others have already told you were talking 40 MAX...no crap its gonna be easier with MT streets
" I don't see 295's or 315's being exactly out of reach for an 8. " UM yes for a street application on a car i dont think he wants 315 70 18 and id love to see you mount a 315 30 18 on a 8" wide rim in your shop...id pay you about a thousand dollars to see that
Old Jun 15, 2006 | 02:38 PM
'86 350's Avatar
Car: '86 Camaro SC
Read his original question tard. Here it is again for you:
He asked the biggest tire he could mount on an 8" rim. Not, "whats the biggest tire with a 40 series sidewall I could mount?" or anyhting like that. I answered his question, but then went on to tell him the more economical choise would be 245/40 or 255/40
"I don't see 295's or 315's being exactly out of reach for an 8. " UM yes for a street application on a car i dont think he wants 315 70 18 and id love to see you mount a 315 30 18 on a 8" wide rim in your shop...id pay you about a thousand dollars to see that
Your right, 315/30/18 couldn't be done..... congradulations first thing you've been right about so far. I didn't say that though. I just said for striaght line and strip combos it's perfectly acceptable and possible to do. I've seen 295/50 or 295/60 mounted on an 8" rim plenty of times. Nice try though cupcake.
Old Jun 15, 2006 | 11:08 PM
ZZ4 86 Z28's Avatar
theres no need for this. it was obviously a misunderstanding with all the people posting.
Old Jun 16, 2006 | 12:15 AM
Car: 1989 GTA
congraTulations you obviously won the argument here and i am so inferior to your miniscule mind power...lets post all of his quote next time and its clear to see hes not talking about DRAG tires...btw i never said anything in the first place to **** you off i just said haha 295 are you serious (bc as YOU even said the idea the way you put it is ridiculous unless you are talking to someone about drag tires)...where did i take a shot at you tard? fact is i didnt but you got all butthurt about it and thats fine...ive got way better things to do then waste my time with someone like you
post a reply if youd like im not reading anymore of your "witty" remarks
"He asked the biggest tire he could mount on an 8" rim. Not, "whats the biggest tire with a 40 series sidewall I could mount?" or anyhting like that." -86350-
Would a 245/40/18 be good for the front? -1FastZ-
THX FOR STRAIGHTENING ME OUT ON THAT
sorry to the poster of the thread it wont be hijacked any longer
Old Jun 16, 2006 | 02:54 PM
'86 350's Avatar
Car: '86 Camaro SC
He asked 2 questions. I answered the first one (what's the biggest tire I could fit on an 8" rim?) and I answered the second one as well, saying that 245/45 or 245/40 would be fine.
congraTulations you obviously won the argument here and i am so inferior to your mind power...
Yeah..... your right. I did win.
Old Jun 20, 2006 | 04:18 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Thanks for the reply's guys. I went with a 255/45/18 on the rear and a 245/40/18 on the front. The 255/45/18 was to big for the front but it looks just right on the rear. All in all I'm very happy with the new look, much better than the chrome 16 inch irocs I had.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
