trans am suspension package
Car: 91 rs
Axle/Gears: 4.10
will the trans am suspension package froman 85 fit on my 91 camaro both have same drive train 700r4 305 tbi
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Yes, but is the 85 suspension high mileage? Also, how are the bushings? I'd be careful about swapping in old/used suspension parts.
I also have a 91 camaro, rs, odo is up to 115,000. After replacing sway bar bushings at about 100,000 miles, the handling increased so much it felt like a different car.
EDIT: I just noticed this should be in the susp. forum.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As mentioned the parts will swap over but I would not use the springs, shocks or struts unless they are new. I would only look at using the sway bars. Everything else is basically the same (panhard bar, LCA).
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Not sure about the trans am lower control arms, but the IROC lower control arms are different thant the RS units. They have (aluminum??) stiffener/spacer bolted into the inside of the arm. At least both my IROCs have them. Never check the Z28, but the 91 RS definately didn't have them. If I could find the old ones for the Formula (WS6 suspension) I check them as I didn' t really pay any attention when we pulled them off.
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
My '88 formula doesn't have the "stiffners".
It has the WS6 setup, which I believe is the same as the trans am's.
hectre13
Dec 11, 2023 08:14 AM
