koni yellows,pro kit & zo6 motorsport
Old Jun 26, 2006 | 01:30 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
just like it says on title
i already have the koni yellows and pro kit on the way and i found a good set of 17x9.5{275 tires} z06 motor sport rims that i want to buy but my question is will this combo actly fit well? also what spacest would i need
my is a black 87 iroc mostly stok
Old Jun 26, 2006 | 04:27 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
common! anyone? somebody has to know somethin!
Old Jun 26, 2006 | 09:39 PM
BADNBLK's Avatar
COTM Editor
Yes! There should be no problems. I had 17x9.5 zr1s with 275's all around and never had a rub. I also have a eibach prokit drop. I have 2" & 2.25" spacers. I was running KYB agx shocks and struts, but should not make a difference. Good luck, it will make your car go around corners like a go cart.
Old Jun 26, 2006 | 11:10 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
thank you for answerig me . who makes the best spacers ? and how much do they cost? any other info would be awsome thanks
Old Jun 27, 2006 | 12:36 AM
CrazyHawaiian's Avatar
Car: too many ...
What you need to do first is determine the backspacing/offset specs of the wheels you want to buy. Then step two will be to do the research to figgure out what size adapters you'll need to fit our cars. If its a commonly used backspacing/offset spec then you can use other peoples experiences as a baseline. For example, if they are 4th gen spec wheels, there are alot of other people running 4th gen wheels, you can learn from their experiences. The bottom line is you'll need to research what works and what dosn't. Don't assume anything.
There's a good thread from a few months ago that showed alot of different wheel combos at different ride heights, some of them were 17x9.5's running 275's on Eibach Pro-Kit springs, so that would give you an idea of what it'll look like. I would start with Andris Skulte's Wheel Adapter FAQ, explains everything you need to know about wheel fitment. I would also recommend buying adapters through him (I went through him when I needed adapters). Check him out at www.skulte.com
Old Jun 27, 2006 | 01:42 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
thank you for the responce and my respeace is being done . im stickin with my 3rd gen rear for the time being.ive been looking around for offest and back spacing to me its confusing even though i have read up on in this week end when i was in school i nad to know that,its confusing for me the reasearch i would need is is wat is the backspacing/off set and finding out wat adapters i need?
thanks man u helped me out in the past and never realy thanked u { wasnt me directly asking the question}
Old Jun 27, 2006 | 01:45 AM
Car: too many ...
Ay no worries, always glad to help if I can. Contact the wheel manufacturer for the wheel specs and go from there.
Old Jun 27, 2006 | 01:59 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
im debating to go with 1 of 2 so far what do u think?
1. http://cgi.ebay.com/ebaymotors/17-CO...QQcmdZViewItem
2. https://host279.ipowerweb.com/~tomzw...38842d63f03ed1
which would you go with? and im picing up on the backspacing and the offset abit more
86Firebird86
Dec 26, 2015 07:21 AM
NiG
Sep 7, 2015 11:25 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
