TIRE SIZE
Car: 1989 Iroc
Engine: 5.7L 350 TPI
TIRE SIZE
i have the 16" iroc wheels, with 245-50-16's on them right now, i am looking at getting a new set of tires my ? is will 255-50-16's fit in the rear w/o and added adapters? any help would be great
thanks
John
thanks
John
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
what's the biggest tire you can put on a 16x8 stock formula wheel? width wise?
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
i have heard of people putting 285's on an 8". but thats rediculous, i think 255 look good, i have 245 right now all the way around and i like them, i think when its time to get new tires ill go with the toyo proxes4 245 all the way around again.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
No one makes a tire bigger than a 255/50 in a 16" rim. So your pretty much stuck with that. The tire is a tad bit taller, but I think it fills the wheel well nicely and it will only effect your speedo by 2 or 3 mph. Depending on how yours reads, it might actually make it read correctly.
Car: 1992 TRANSAM 1989 FORMULA 350
Engine: L-98 350
Transmission: FIRM SHIFTING 700-R4
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I also have a 275/50/15 on my 15x8 and I definently wouldnt recommend bigger than that.
Car: 84' Monte
That's just it guys, he wants the biggest tire for his 16x8 wheels. There is only 1 or 2 tires available that are bigger than 255, BFG makes a 295 which is WAY too wide for an 8" rim. Also with a 16" rim you start loosing some of your sidewall that you guys with 15's are using to take up the mismatch between the tread width and the rim width. 255/50/16's fit about perfect on a stock rim. They don't buldge, they are only slightly bigger in diameter. They actually look nice and square on the rim, which gives them the appearance of a bigger tire. I actually got more even tire wear with a 255 than I did with a 245. With the 245's I was burning the edges off, with the 255 the tire wore much more evenly since the sidwalls were more vertical.
I too would like to know the maximum height and width of tire that will fit underneath a 1987 IROC Z/28 (both front and rear); I'm running 17 x 8.5 Edelbrock 454 rims with the standard offset all the way around. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
