mini tubs
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There are no real "mini tubs" on a third gen. The inside of the fender is already at the "frame rail". The best you can do is increase the radius at the front of the inner fender to allow a taller tire.
About the only thing you can do to increase the width is to cut off the bump stop mount and weld a plate over the hole.
Or you could buy these
Wolfe Race Craft - Detail
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
all i want is a 10" wheel with 6.5 " of back spaceto move the tire in a little bit. i already have a 10" wheel with 5.5 " of back space , they hang out a little bit. i would like to have a 10" wheel with 6.5" of back spacing
