Where did you put the smaller passenger side piece when installing Spohn SFCs?
Old Jul 12, 2006 | 07:51 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I was at my cousin's shop today and we were working to install my Spohn SFCs. Everything was going smoothly but we couldn't come up with an obvious location to put the smaller T-piece on the passenger side. The cat always seemed to get in the way and even if there was no cat there was no obvious location. Is it okay to go diagonally? How much contact must be made between the smaller pipe and the main SFC shaft? Is just one small weld on the top of the main shaft sufficient?
Old Jul 12, 2006 | 08:49 PM
EvilCartman's Avatar
Car: '82 Z28
Talking about this one?
Old Jul 12, 2006 | 09:12 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Yes, thats the one. I've seen that pic but I cant really tell how its attached on the right side of the pic. Is it just that one tack between the sections of pipe?
Old Jul 12, 2006 | 09:23 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Hmm, that doesnt look like a very strong Y brace weld there. But that is from Spohn's website, so I guess thats how it goes.
Old Jul 12, 2006 | 11:01 PM
Car: '82 Z28
Looks like it's only welded on the one end a little bit, maybe out of site it's welded to the floor pan a little too.
Old Jul 13, 2006 | 01:49 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
My cat is really close and would likely touch the tube if I put it there. Should I worry about the cat transferring heat through the SFC to the floor pan and melting the carpet/starting a fire?
Old Jul 13, 2006 | 06:33 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
It won't transfer that much heat
Old Jul 14, 2006 | 03:50 PM
jonarotz's Avatar
Car: 91 Z28
I heated mine up and bent it so I could get a solid weld to the connector and still clear the cat.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
