I want 20's on My GTA
Old Jul 20, 2006 | 10:18 PM
GTA_IN_T.O's Avatar
Hey Guys
Anyone running 20's on their car?
I was thinking a 20x10 with a 285/30/20 for the rear
19x8 with a 255/35/19 for the front
Wasnt able to find alot of options for rims, this is what i have narrowed it down to, available in chrome or grey (polished)
Any chance of someone being able to photoshop these rims into a burgandy GTA
http://customwheel.com/custom_wheels...s/typemesh.jpg
BFGoodrich g-Force T/AŽ KDW NT Tires - Tire Size & Price Details - 1010tires.com
Old Jul 21, 2006 | 10:22 AM
GTA_IN_T.O's Avatar
Anyone???????? No one with 20's on their car???
Old Jul 21, 2006 | 12:07 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
well one question y ruin a perfectly good car by doing something like that to it?
Old Jul 21, 2006 | 12:13 PM
GTA_IN_T.O's Avatar
why am i ruing it?
I want a bigger tire and rim, i have searched hi and low no one make a replica GTA rim in bigger sizes
Old Jul 21, 2006 | 12:21 PM
sicc87's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: auto 700-r4
ive seen a few down here in socal they look pretty sweet. although of course it wont perform as well but if u only want it for aesthetics then go for it.. its your car. Ive seen a sunburst orange 4th gen T.A around here with 20's and man it looks killer. the car is gonna feel way heavier but like i said, if its for cruising and w.e then do it man.
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
I will be doing the same to my car sometime in August. I'm just trying to find the right look. I know another guy here on the site has a 19/20 combo and it looks real good. Your best bet though is to find a tire & wheel combo that is close to the overall diameter of your current setup so you can avoid any rubbing.
Jay
Old Jul 21, 2006 | 12:46 PM
Shagwell's Avatar
Car: projects.......
It could be done, as stated, you'll have to run a tire approxiamtely the same height & width as factory to keep it from rubbing. This means very little sidewall which will make for a very stiff/rough ride and make it very easy to bend a wheel. The biggest negative is the loss in performance. That large of wheel is heavy and most are cast, meaning very heavy which translates to a lot of centerifical weight. Many GTA's came with a aluminum driveshaft, which was considered a performace option. - If the weight of a 3" ds makes a difference in centerifical weight, just imagine what wheels do....
Looks wise...to each his own. Personally I think they're too large for the wheel well, so they don't look right on the car.....The arc of the wheel is larger than the arc of the wheel well, just doesn't fit.....
Old Jul 21, 2006 | 12:48 PM
BADNBLK's Avatar
COTM Editor
There is a guy on here that has 19& 20" combo. I belive his screen name is shawn18jgr.
Old Jul 21, 2006 | 12:52 PM
GTA_IN_T.O's Avatar
I am not to worried about weight wise, not just doing it for cosmetic reason either. The car is gonna get supercharged, with maybe a 400 small block so i am not to worried about horespower. Its a street car, a fast one.
Old Jul 21, 2006 | 12:56 PM
Shagwell's Avatar
can you say tyre fryer? - if it can't hook it won't be fast and you'll still have all that extra stress in your driveline because of that weight, and your brakes will also hate trying to stop them....
no disrespect intended, just pointing a few things out...
Old Jul 21, 2006 | 12:58 PM
GTA_IN_T.O's Avatar
Originally Posted by Shagwell
can you say tyre fryer? - if it can't hook it won't be fast.....
Who cares about hooking it for highway fun
Going to being doing either Baer brakes or SSBC
I found him........his ride looks sweet, i am now sold on the 20/19 combo, just have to decide if i want chrome rims, not sure if it will be too flashy
http://www.cardomain.com/ride/2261839/1
https://www.thirdgen.org/forums/memb...hawn18jgr.html
Last edited by GTA_IN_T.O; Jul 21, 2006 at 01:01 PM. Reason: Automerged Doublepost
Old Jul 21, 2006 | 02:05 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
You want black rims with polished lips. CCW classics or similar forglines. Maybe work wheels...they have a crosslace style look to them.
here are a few to ponder buy will still keep with the gta's style..
Attached Thumbnails I want 20's on My GTA-work-vsxx.jpg   I want 20's on My GTA-tire1.jpg   I want 20's on My GTA-volk-gtu.jpg
Old Jul 21, 2006 | 02:07 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
oops CCW classics...
Old Jul 21, 2006 | 02:45 PM
GTA_IN_T.O's Avatar
the middle one doesnt look bad, just all those damn studs all around that i hate
Old Jul 21, 2006 | 05:04 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Thats because most of them are true 2 or 3 piece wheels...though im sure you could get them with the studs painted to match the center so they wouldnt stand out as much
Old Jul 22, 2006 | 03:08 PM
BADNBLK's Avatar
COTM Editor
The rivets are the best thing about the wheels. Like was said above the wheels that have real rivets are a usually 3 piece wheels, and that establishes that you spent a sh*t load on your rims! Dudes with half a** cars are not going to drop that kind of dough on 3 piece wheels, so if you have them to me it means that your car is serious without even knowing much about it other than the wheels are dope.
Old Jul 24, 2006 | 06:08 PM
Dans87GTA's Avatar
you say highway fun but your going to put heavy tires on think about it? put bigger brakes on it thats find i dont think it will help all that much! good luck but i still think your ruining a good car just go DUB CITY on it. just my 2 cents.
Old Jul 27, 2006 | 02:01 AM
shawn18jgr's Avatar
Couple pics from tonight...
Old Jul 27, 2006 | 12:43 PM
Shagwell's Avatar
^^^ those are a lot like my Blaster 5's, but mine are 17".
- I will note that lighter wheels can be had while going larger diameter, but I don't think you'll see lighter than factory at over 17" my 17x11 billets and the 315/35/17 nittos weigh the same as the factory wheel and 255/50/60 kumho that I took off. My fronts are lighter.
No matter highway speed or drag race, more centerifical weight still requires more power to accelerate. It may take less power to maintain, but always more to accel and more to stop.
..yeah, because 100+ mph freeway runs are soo safe/legal....reminds me why I want my g/f in a larger truck.....
Old Jul 27, 2006 | 04:06 PM
BADNBLK's Avatar
COTM Editor
Your car is soo sexy! Your car is the perfect example of how great the 19& 20" combo can look on our cars. Because of yoru car I am thinking of selling my NEW 18's and getting some DUBs! If I sell them I am PM-ing you to talk about tire sizes, and such.
Thanks for the new updated background of your car!
Old Jul 27, 2006 | 04:11 PM
GTA_IN_T.O's Avatar
The more i look at shawns car the more convinved i am, just have to find the perfect rim
Old Jul 28, 2006 | 12:28 PM
Shagwell's Avatar
his car does look good. - What/whose wheels are those? They look a lot like my coddingtons'.
- still not trading in my 17's, just giving a compliment where its due.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
