strut tower brace?
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
strut tower brace?
I have a '84 T/A (carb) and I can not find a strur tower brace anywhere. If I had EFI there would be no problem, but I do not. I would even be happy making one myself. If anyone has knowledge on making one or where to purchase a bracket that will fit...... Your help would be appreciated.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by midniteplowboyy
Why cant you use one off a TBI car?
JamesC
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
from what understand the A/C bracket can me ground allitle where it gets in the way, I just got done putting the STB in my car (well the brackets at least...I can't permanatly install the brace W/ the engine out...I did put a mockup plastic engine in to see how everything would fit) and it looks like it will fit fine, or mabe just touch the A/C bracket, which can be easaly modded W/ a grinder
Engine: 383
well...it might be while....I go on leave aug. 3rd, a SSgt. in my shop is supposted to finish the engine(he has all the tools verses me doing it here at my appt, which dosen't even have a garage) and install it if he has time....if not I'll get it in after I get back
Axle/Gears: unknown
hey, thanx for the picture Iron Duke. If I mfg. one this will come in handy!
I have deleted all my A/C under the hood. I also changed the heater box to a non-a/c model, I can actually see the entire passenger side of the engine. I cut the ac/ps bracket so it still holds the p/s pump. does this mean I can use a brace for a TBI model? As far as I know the braces for the tuned port models sit further back towards the firewall, it would go thru the carb.
I have deleted all my A/C under the hood. I also changed the heater box to a non-a/c model, I can actually see the entire passenger side of the engine. I cut the ac/ps bracket so it still holds the p/s pump. does this mean I can use a brace for a TBI model? As far as I know the braces for the tuned port models sit further back towards the firewall, it would go thru the carb. Senior Member
Engine: 383
yup if U have no A/C the TBI brace will bolt right in W/ no clearance probs whatsoever
LT1Formula
Oct 8, 2015 08:34 PM
tcflint
Sep 27, 2015 05:58 PM
