Is everyone elses roll bar look offset?
Old Aug 14, 2006 | 08:58 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
We finally got around to welding in the main hoop, rear strut bars and cross bar. I never really noticed until tonight that the rear subframe sits offset from the body, like its moved to the driverside about 6 inches or so. So for the passenger side strut bar it was no problem. but the driver side strut bar I had to come off the rear subframe at a very slight angle to mate it with the main hoop.
I also had to bang about a half-fist dent on the driver side above the gas tank for the strut bar to clear. Im using the CE 8pt kit, anyone else run into this? I was gonna use the door bars as the strut bars for more clearance, but from what I remember that wasnt gonna help me out much.
Old Aug 21, 2006 | 09:46 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
I like to tie in directly over the rear springs, and I have never encountered any problems in an 82-92 F-body when installing them (rear struts) in this fashion.
Old Aug 21, 2006 | 11:05 PM
spills's Avatar
Car: 89 RS
Ive seen a lot of people do that, but I went by the instructions that came with the kit and it said to weld it over the rear frame rails. I could see though having them over the springs helping out with hard launches, but I was more concerned with overall body flex. I honestly really didnt give it much thought about where to put em, Ill get some pics next time I go over to the guys shop.
Old Aug 22, 2006 | 12:59 PM
Shagwell's Avatar
Car: projects.......
yes, all of our rear subframes are "offset" in this fashion. Depending on placement of one side from the other you can end up with the bars running at the same(mirror) angle from each other. - My bars tie in at my spring pockets, should create more strenght in the suspension, plus the trunk shelf is where my top lays when it's down, so bars all the way to the back were not an option.
- I think ideally(hardtop or t-top) I would run the rear bars all the way to the back, then add an x-brace that went from the main hoop down to the spring area.
Old Aug 22, 2006 | 01:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
these cars arnt very symmetrical... almost everything from the floorpan to teh subframes to the engine offset, differ....
Old Aug 23, 2006 | 08:34 PM
Shagwell's Avatar
Old Aug 25, 2006 | 11:35 PM
spills's Avatar
Car: 89 RS
thats good to hear, I still gotta fit the door bars but after that I might try and tie the bar into the spring pockets. I still got the 2 bars that are supposed to go to the trans tunnel, but I aint runnin a 4 link or anything so I dont see a point in running those to the trans tunnel (at least thats where the directions show theyre supposed to go)
J-money
Jan 4, 2019 09:45 AM
scotrans am
European Region
May 30, 2018 03:48 PM
SG91camaro
Sep 5, 2015 10:27 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
