Good cheap reat shocks for drag racing
Old Aug 22, 2006 | 05:44 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I was really dissapointed in my 60 foot times the last few outings at the track. I took one of my rear shocks loose only to find that it completely compresses on its own! I'm looking for something that I can get local and decently cheap to remedy this problem. I've heard recommendations for the Heavy Duty truck shocks I'm assuming they're stiffer and this will help me put more force on the tires. If I can't find anything else I'll probably go with Gabriels from Auto Zone or buy a set from the Junkyard (YIKES!). Thanks in advance everyone.
Old Aug 22, 2006 | 12:32 PM
Shagwell's Avatar
Car: projects.......
I'm cutting 1.6x's on cheap azz monroe sensajunks. I've got all aftermarket rear suspension though.....
Old Aug 22, 2006 | 01:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
depends on your choice of suspension hook style.. but for a soft shock, the cheapie red ryders from autozone... for a cheap "50/50" shock, the gas charged Monroe's work well.
Old Aug 22, 2006 | 02:34 PM
I'll probably go with the gas charged Monroes, I have the cheapie red shocks in there now that's what blew out on me. Thanks for the fast replies guys.
Old Aug 22, 2006 | 03:59 PM
Stevo's Avatar
Car: Pair of 92 Z28s
kybs are cheap and stiff...cant be too much more then the monroes?
Old Aug 23, 2006 | 08:26 PM
Shagwell's Avatar
The KYB's are a bit stiffer than the Monroe's and if you're running a factory type tq arm(not a shorter version) too stiff of a shock can hurt straight line traction.
- The shorter tq arms' react faster, thus usually require a stiffer shock/shock setting(if adjustable) to keep from having the rear re-bound after initial hook. Longer tq arm(such as the factory) don't react as fast, thus too stiff of shock will slow reaction more, thus not plant the rear.
This plus other variables are what makes adjustable shocks so nice. Double adjustable go yet the next step allowing you to control extension and compression seperately, thus giving you infinite tuning for perfecting any application.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
