steering box
Old Aug 26, 2006 | 09:04 PM
tippmann243's Avatar
Car: 89 s10 blazer
Engine: build 4.3
Transmission: t56 6 speed
Axle/Gears: 4.56's
steering box
ok guys i got an easy question
on the 3rd gen cars do only the irocs come with the quick ratio steering gear box or is it all 3rd gen cars?
Old Aug 26, 2006 | 11:07 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
wonder if this will work...well it worked so i'll explain what i have determined it means....
the "WS" (z28) box and the "XH" (iroc) box have the same ratio...but the "XH" box was equipped on the cars with 16" wheels and it had slightly different internal stops to keep the tires from rubbing on the front subframe. It also is supposed to have more roadfeel/steering effort (feedback).
...at least thats what ive interpretted from it.
File Type: doc
Old Aug 27, 2006 | 03:17 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
trans ams too...
and dont forget other models of cars such as some montes and so on and so forth
all depends on packages ordered
Old Aug 27, 2006 | 12:00 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
OK OK 3rd gen firebirds too...If you go outside of third gen cars, such as monte carlos, you could possibly run into problems with your turning radius, with the other cars steering geometry the swap may work one way but not the other.
Old Aug 27, 2006 | 01:34 PM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
i was asking because ive heard rumors that the iroc sterring box is the same one that is used in the zq8 s10's
the zq8 stads for the sport suspension package adn it lowers the truck 1.5", has larger sway abrs, frame brace better shocks in some cases a 3rd rear shock and has a quick ratio steering box
people who have zq8 boxes are very proud of them and used ones go for 120-180 so if i could pick up a decnet milage f body one adn ahve it be the same then i would be saving some decent coinage
thanks
-mark
83 Crossfire TA
Jan 3, 2016 01:26 PM
bubbaz28
Sep 18, 2015 02:09 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
