diff. wheels and tires...darting..
Old Sep 5, 2006 | 04:17 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
i put some used wheels and tires on my camaro, they are wider and an inch shorter than the stock set up...going about 60, it seems as if it is darting.. not bad..but you gotta keep ur hands on the wheel..and coming to a stop from about 15mph to a complete stop i feel vibration on the brake pedal..not IN the brakes but on them.....help please!!
Old Sep 5, 2006 | 04:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like a wheel imbalance issue
Old Sep 5, 2006 | 04:35 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
will it be safe to drive..?
Old Sep 5, 2006 | 04:45 PM
xpndbl3's Avatar
Car: 1984 Z28
it'll be safe to drive to a tire shop and spend the $20-30 to get them rebalanced
Old Sep 5, 2006 | 07:16 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You said the tires are 1" shoter. May be you have screwed up the alignment. Make sure the assemblies are balnced and get an alignment.
Old Sep 5, 2006 | 10:21 PM
xpndbl3's Avatar
Car: 1984 Z28
tire height won't effect alignment, still sounds like a tire imbalance, if pulling only during braking it may be due to a brake issue, ie collapsed brake hose, stuck caliper, etc etc
Old Sep 5, 2006 | 10:24 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
it doesnt pull during braking...someone thought maybe cuz they have been sittin on a car thats been sittin for a few months...im just drivin to school and around town...so i should be alright...i dont think it threw my speedo off too much???....and when im goin 60..it kinda feels like it weaves..but the car doesnt really move??? i dont know if u understand but yeah..
Old Sep 6, 2006 | 02:35 AM
CrazyHawaiian's Avatar
Car: too many ...
It might be uneven tread wear from a bad alignment on whatever car it was on previously. Use a tread depth indicator and measure the tread across the contact patch, see if its even or not. The tire/alignment shop will also be able to tell.
Old Sep 6, 2006 | 07:29 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
they were on my berlinetta..and when i had them off..one tire on the front seemed to have a little more tread on the outside than in..not much...but maybe i was seen things
Old Sep 6, 2006 | 12:24 PM
Shagwell's Avatar
Car: projects.......
If the tread wear is uneven it could easily cause pull, vibration, etc. Depending on how long they sat the balance could easily be off. If they're old enough that belts are shifting, they could also pull due to that. - IF you don't know, have them checked by someone who does, or you could be fixing a quarter panel if they come apart....
Old Sep 6, 2006 | 04:08 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
i guess i should get them checked...like i said..well maybe the've been sittin about 6 months..? 5?? not sure...the tread is "good" on them tho..
junior419
Apr 7, 2025 11:35 AM
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
rudolphschenker
Sep 4, 2015 02:41 AM
