bbc swap springs?
Old Sep 13, 2006 | 09:53 PM
sam roth's Avatar
bbc swap springs?
hey i havent bought the car yet, but if i get one with a 6cyl i need a recommendation on good springs to handle the added weight with my 454, i've heard small block springs will handle it, but just in case i buy one that had a 6 banger in it, id rather buy some new performance springs than rip some out of a small block car in the junkyard since they arent that high, thanks!
Old Sep 13, 2006 | 11:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
don't buy used springs, they're worn out anyway.
I'd recommend moog 5664's, they're stock replacements for like a '93 S10, or the heavy duty suspension on the convertible 3rd gens. They're the stiffest stock ones you can put in these spring pockets (that I know of). They are also stiffer than many aftermarket lowering springs, plus, the true beauty, they're CHEAP like stock parts, not like "high perf" stuff, plus you can get them at any parts store.
Old Sep 14, 2006 | 07:48 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I run V6 springs in my car but then my car's weight is less than a factory car.
Old Sep 14, 2006 | 10:51 PM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
Your best bet is put the new motor in and then weigh the front half of the car and get the correct spring rate for whatever it weighs.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Cameeeero
Sep 18, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
