4th Gen Wheels Questions
Old Sep 19, 2006 | 03:06 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Looking at some new wheels for the 92 maro. Found these locally for cheap:
The question is: will these fit right up without any fitment or rubbing issues? The car came with the 16" Z28 wheels if it matters.
I would be taking it to a shop to get them swapped of course.
EDIT They are from a 2002 Firebird if it matters.
Old Sep 19, 2006 | 05:38 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
You need to know the same information as me. No one seems to want to respond though.
You will need spacers in the front and back, but I need to know the correct size spacers as well, and as far as I know, they are not cheap.
Old Sep 19, 2006 | 07:34 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
no one responds because it has been covered millions of times do a and find out what happens you will be amazed dont mean sound like an *** but always try that first if you cant find the answer then do a post. Later Daniel
Old Sep 19, 2006 | 09:04 PM
ecetim's Avatar
Engine: 5.7L L98
Well I thought I did search well enough, but I found a thread saying you need 2" spacers for 17" 4th gen wheels.
Is this the same for 16" wheels?
What is the disadvantage to having to use spacers, if any?
Old Sep 19, 2006 | 09:17 PM
You try searching through all of the BS threads for one particular thing, you could spend hours doing it. Usually to find nothing, and I usually do search before I post, but everytime I get no luck.
I have heard that you need a 2" spacer in the back, and a 2.25" spacer in the front. But one member had to use a 2.5" spacer in the front.
Old Sep 20, 2006 | 04:30 PM
Dans87GTA's Avatar
well i know everytime i have posted it takes a couple hours to get an answer from somebody so either way it takes alittle bit and i know i did a search and i found all the info i wanted to know in less than an hour and i dont know what your problem is! as for the front 2.5" spacer i dont think so anytime i have talked to anyone 2" has always came up and sometimes it has been 2.25 if you want them to stick out alittle.
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
