Which coil spring compressor?
Old Sep 23, 2006 | 06:15 PM
Guest
Guest
Posts: n/a
Hi,
Please tell me what kind of spring comressor I should use
for the front coil springs. I have an 1984 Firebird Trans Am.
I am beginner, I never lowered a car until now.
I have a compressor but I had to make it shorter because it was
too long. And the problem is now that there is not enough space
around the spring to place this compressor. I can only place
one compressor on the side near to the brake disc. But on the other side
(near to engine) I can not place any compressor. Or the compressor
should be put inside the spring through the hole in the control arm?
I could not compress the spring with this one compressor placed outside, the spring still pressed the control arm very much.
Please tell me which compressor I should use and please send me
pictures about how it looks and if it is necessary please explain me
how I should use it. Thank you very much.
Regards,
Laszlo
Old Sep 25, 2006 | 09:12 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
As far as I know, you should take the struts and stuff out of the car to switch springs and stuff out. As far as types of compressors, I'm not sure. You could have a shop do it for you in probably an hour or two.
MM2Robinson
Oct 1, 2017 09:16 AM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
