sway bar
Old Sep 26, 2006 | 04:20 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
sway bar
I was in a little fender bender a while back. When I did my engine swap, I pulled everything off including the swaybar. I noticed that it wasn't "symmetrical" are both sides bent equally? It's not bent that much more on one side, but I don't want it to infere with the drivability.
thanks in advance
Old Sep 26, 2006 | 10:13 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Should be symmetrical.
Everything I've ever owned GM has had symmetrical sway bars :-)
It prolly got tweaked a little.
later
Jeremy
Old Sep 27, 2006 | 09:12 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Should I worry about it?
Old Sep 30, 2006 | 07:36 AM
3.8TransAM's Avatar
Bent bar can cause stree on other suspension components and keep them partially loaded.
Also would make for uneven handling depending on whats already loading from being bent and what deflection it has from not being symetrical any longer.
Could give your car the twiitches,
later
Jeremy
Old Sep 30, 2006 | 07:48 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
sway bars don't bend very easily, I'd R2 the sway bar and look for other damage as well, something ells more important could also be bent
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
