Speed Ratings, going over?
Old Oct 1, 2006 | 03:19 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey, I'm wondering if anyone has blown a tire due to exceeding the speed rating. A friend of mind told me he was going 140 in an SHO Taurus, and he knew the speed rating was less then a V.
What are the details of exceeding the speed rating?
Old Oct 1, 2006 | 03:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Before everyone comes on here and starts talking about how they went 130MPH in their old beater caprice and nothing fell apart....
It's just for warantee or liability. You can usually go pretty fast in a low speed rated tire - just not for a very long time, or if the tire is super old.
If you blow a Z rated tire going 100MPH, you can probably sue, and or get a bunch of free tires. If you blow the low speed rated tire (say, H?), at like 150MPH, you don't have much recourse as far as law/warantee goes...
Old Oct 1, 2006 | 03:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Speed ratings are based on a sustained speed over a period of time. If you're running 100 mph for about an hour, the tire will heat up a lot. A higher speed rating tire will prevent the tire from heating up and causing a failure. The speed rating is also based on the load of the tire.
Of course there's always those people who have speed rated tires which are designed not to heat up and they're in the water box trying to smoke the tires to heat them up. It just doesn't work.
There are many fast cars on the dragstrip that do not have speed rated tires. They're just not at those speeds long enough to affect the tires.
For those short bursts of speed, a standard H rated tire will survive just fine but if you're running in the Silver State Challange, part of the rules is that you have speed rated tires at or above the speeds you'll be running.
Having speed rated tires also means running them at the proper air pressure. The tire is trying to disipate heat and if it's underinflated or overloaded, it produces more heat than normal and the speed rating decreases.
Old Oct 1, 2006 | 11:35 PM
Guest
Guest
Posts: n/a
Dont know if it was related, but yes I've blown a tire sustaining a speed above its rating and it was a nasty blowout.
PurelyPMD
May 5, 2016 04:57 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
