rear springs
Old Oct 5, 2006 | 07:50 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
rear springs
im looking for springs that i can lift the rear end a little bit, does anyone know where i can get them from thanks chris
Old Oct 5, 2006 | 08:19 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
typically moog stock replacement springs will lift them more than enough since factory springs by now will be sagging.
Old Oct 6, 2006 | 04:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My Eibach Pro Kit lowering springs (1 inch drop) actually raised my rear end my springs were sagging so bad - and I have a 1992!
Old Oct 6, 2006 | 06:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'm with xpndble
moog
cc635 is the cargo coil, ie, variable rate style
and 5565 (I think...) is the straight rate for the rear of these cars.
I use the cc635's, with some nice big 275/60R15's out back to have a nice raked stance
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
