C6 rim questions
Old Oct 9, 2006 | 07:00 PM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
C6 rim questions
Ok so I bought some original C6 rims off a corvette guy and I'm debating on what tires to put. His corvette had P245/40R18 up fronts and P285/35R19 on the back. Should I stay with the same size or should I get different tires. Your opinion please. What kind of spacers do you recommend. I've searched and I found that you can use 2 or 2.25 inch spacers. Which one should I use. Also take into consideration that I have a 4th gen rear end installed. Any help and pics would be appreciated.
Old Oct 10, 2006 | 04:23 PM
Car: 1989 Camaro RS
Anyone?
Old Oct 10, 2006 | 08:52 PM
trigger GTA's Avatar
Car: 92 TA vert
wheel size is up to you. personly i dont like alot of rubber hanging over the rim. but bigger rubber will fit on the rim and in the well.
i have 2001 vette rims with 2inch spacers in the front and back. with a forth gen rear end i dont think you will need any spacers but i am not 100% on that one
Old Oct 10, 2006 | 11:28 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
my mom has c6 rims on her c5 and she ended up getting a 1" adapter for the rear. that put the tire just in side of the wheel well. with out the adapter the wheel would not fit it would hit inner wheel well, it needed atleast 3/4" to clear. A f-body may be different, I'd bolt it up and go from there
Old Oct 11, 2006 | 05:41 PM
Car: 1989 Camaro RS
What size of tires are your running all around trigger GTA? I'm looking to leave stock ride lift in the back but a wider tire. Any ideas
Old Oct 11, 2006 | 06:05 PM
Car: 92 TA vert
front are 245/45/17
rear are 275 40/18
next time i buy rubber i will be going
front 275/40/17
rear 295/40/18
Old Oct 11, 2006 | 09:16 PM
Car: 1989 Camaro RS
Do you think those sizes will rub any?
Old Oct 11, 2006 | 09:22 PM
Car: 92 TA vert
it might up front.
i know a few poeple running that size some do and somedont.its right on the edge. if the car is lowered then there is a very good chance it will rub. i have one car that will rub with stock rubber because of the drop.
i cant say. best would be to check with a tire shop. and even then the only way you will truely know is when its on the car.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Djmathis123
Sep 29, 2015 01:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
