Ground control weight jacks?
Old Oct 10, 2006 | 02:32 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Anyone have opinions on these? I have read some topics that talk about them, I want to know how they ride on the street, how easy are they to adjust? Could I adjust for show versus, driving or is it kind of a hassle?
When I am looking at purchasing them, sometimes it mentions fronts, These are for all four corners correct? The fronts wrap around the struts? Do the rears go in stock location of original springs?
Thanks for any answers you guys can give me.
Old Oct 10, 2006 | 12:49 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
I second all of his questions.
Old Oct 10, 2006 | 02:10 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Depends on the spring rate you go with and the shocks that you run.
Fronts are fairly easy with a large 1/2 inch ratchet and a 10 inch extension. Rear are a pain, needing the rear axle completely unloaded to do.
It a hassle and I wouldn't advise it, get air bags if you want to do this.
There are front and rears, but each end is of a different design.
No.
Yes.
A search would have found this thread: https://www.thirdgen.org/forums/susp...ght-jacks.html
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Linson
Nov 12, 2015 08:09 PM
