EATON LIMITED SLIP QUESTION!!!!!
Old Oct 10, 2006 | 01:52 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
I have a new Eaton limited slip carrier unit that I can buy for $250.00. It is brand new and the part # is19663-010. I have a 1985 Iroc-Z, TPI 305, 700r4 trans. with a 10-bolt, 26 spline axles and 3.42 ratio gears from the factory. I need to know if this is the absolutey correct part for my differential. Thanks, Badman
Old Oct 10, 2006 | 07:19 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
you should post this in the "Transmissions and Drivetrain" section of the forums. are you sure you have a ten bolt and not a borg warner? i have a 10 bolt and my axles have 28 splines, but my car is a 1991 so they may have changed it
MustangBeater20
Oct 29, 2022 09:20 PM
billybob6110
Sep 24, 2016 09:50 AM
Warlocksirix
Sep 3, 2015 12:26 PM
someone972
Aug 30, 2015 12:52 AM
redmaroz
Aug 16, 2015 11:40 PM
