Where to buy..
I don't think you're gonna find 1/2" spacers. The lugs would stick out further than the thickness of the spacer, thus not allowing the wheel to seat. - The only way you'll probably come up with that is to switch to a long set of studs and run open spacers. If you go this route, you'll also need thicker studs to handle the load.
lopezisgod
May 31, 2010 08:50 PM
