MPFI to LT1 FUEL LINES The end all post.
Old Apr 29, 2010 | 11:19 AM
kukerdan's Avatar
Hey guys, I know the info is supposed to be out there, but im having a hell of a time finding it, maybe this is sticky material.
2.8 mpfi camaro hard lines to the lt1 lines....
Can anyone tell or show with links Exactly what i need to, or should buy..
I understand I can mate the two with a set of adapters on one end or the other, but I cant find out what that is. I also realize my other choice is to put all new braided fuel lines in the car.
I went to a few auto parts stores, apparently they cannot look up what size or fitting is used, and NEED TO SEE the lt1 fuel rail and the ones on my car... I dont understand how they cant look two STOCK pieces of information up, but anyone, im at a loss, and have no idea what to buy...
Can anyone help with a link or two? or some number I can go to the auto parts store with.
thanks
Old Apr 29, 2010 | 08:11 PM
carkook's Avatar
Re: MPFI to LT1 FUEL LINES The end all post.
Contact Pure Choice Motorsports, you can find them online or call (888) 505-8355. Real knowledgable staff. I called them told them what I was doing he knew exactly what I needed. I believe it was 120 bucks after shifting for really nice steel braided lines. Fit perfect and look amazing.
Dont cheap out and try and do it yourself with janky adapters. Wouldnt want a hose to bust and pump gas at 40psi into your engine bay.
Old Apr 29, 2010 | 08:23 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Yea, feed line is 3/8ths, and return is 5/16ths. You need quick connects on the LT1 fuel rail and I was told the ends of our factory fuel lines were the same ends as power steering lines. For my setup, I'll be using factory quick disconnect lines from a different gm car. After my car is all together, I'll post up how they are. But for $7 for all the line i needed and everything sure beats $120, and you can't say skimping is bad, because this is factory GM stuff, not fancy like braided lines, but factory parts none the less. I'll post details within the next two to three weeks when my car is all together.
Old Apr 29, 2010 | 08:27 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Are you wanting to convert to -AN fittings and braided lines?
Old Apr 29, 2010 | 08:30 PM
dctrumpet's Avatar
The actual fittings on the hardlines coming from the tank and connecting to the lines under the hood that go to your throttle body are 16mm X 1.5 for pressure side and 14mm X 1.5 on the return side.
I am really not too sure what you're needing. I posted a while back with pictures. Not sure where that thread is now lol.
Old Apr 29, 2010 | 09:51 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
made my own using quick disconnects from Auto Zone, some FI hose clams, FI hose and the original hoses that went to the V6 fuel rail, haven't had a leak in over 5 years and holds pressure like it should
Old Apr 30, 2010 | 10:25 AM
Pocket's Avatar
Car: 91 Trans Am
Ill draw a new diagram up tonite
Old Apr 30, 2010 | 10:43 AM
kukerdan's Avatar
Hi
Ok guys here is what I did... I bought the quick disconnect 3/8 and 5/16 for the lt1 fuel rail it came with hose fittings i cut the ends off the body lines and put the new lines inside the body lines with the hose joiner fittings, and used high pressure fuel line hose clamps to hold it all together worked really nice,
thanks!
Old Apr 30, 2010 | 10:56 AM
Pocket's Avatar
Car: 91 Trans Am
I would suggest against simple clamps on a high pressure EFI line
Old Apr 30, 2010 | 01:05 PM
kukerdan's Avatar
they are high pressure fuel line clamps
Old Apr 30, 2010 | 02:13 PM
Pocket's Avatar
Car: 91 Trans Am
Cut the plastic line off the quick connect barbs and run your EFI hose all the way up. Clamping down on plastic lines is risky business
Old Apr 30, 2010 | 03:49 PM
Klortho's Avatar
Car: 1987 GTA
Yeah, the quick disconnects I used were metal with flares on them, I cut the hard lines that went to the fuel rail of the V6 on the side that went to the factory rubber lines, flared the ends and put them on the other side of the FI hose I bought.
Old Apr 30, 2010 | 11:03 PM
kukerdan's Avatar
they are clamped on the larger hose side of the metal barb, which is inside both tubes
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
