springs coming loose?
Old Oct 19, 2006 | 09:58 AM
bfox88's Avatar
Car: 90 IROC-Z
i'm considering buying some lightly used aftermarket lowering springs, but the seller says that the rear springs would pop out of place if the rear of the car was lifted up. he says he was running a 4th gen rear if that makes a difference. is this a common problem, because i've never heard of this happening?
also do any companys make sfcs for factory dual cat cars?
Old Oct 19, 2006 | 04:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by bfox88
ithe seller says that the rear springs would pop out of place if the rear of the car was lifted up.
The rear springs will essentially fall out if the car is raised and the rear end dropped a bit. No doubt have to unbolt the shocks for this to happen.
JamesC
Old Oct 19, 2006 | 04:49 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
If you are lower enough, with higher rate springs. I can change rear springs, without unbolting the shocks, just lift it up, and pull the springs. Now, it is pretty hard for the springs to actualy "fall out" due to the shape of the spring pockets. If you are REALLY worried about it, zip tie the springs to the rear axle, or install limiting straps.
Old Oct 19, 2006 | 09:07 PM
bfox88's Avatar
Car: 90 IROC-Z
thanks for the quick replies guys. so essentially this isnt a problem i should be worried about and have no fear in buying the springs?
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
