Suspension is dying!!
Old Oct 21, 2006 | 04:13 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Yesterday I was driving to my boss's house.. car was driving fine.. I get to the boss's house and as im leaving I notice a weird feeling in my steering wheel and a weird grinding noise coming from my front end. As I was driving it kept getting worse and worse. It finally got to the point where its going KER KLUNK KER KLUNK KER KLUNK. I get to my shop and I jack my car up, my wheels move side to side a little bit *both of them*. Also, I dont know what it is.. but its a vertical rod with two rubber "gromet" things attached to each end of it, it has a lot of play in it. I know absolutley NOTHING about suspensions.. im totally clueless as to what to do..
When I hit my brakes, my steering wheel kicks to the left a little bit and the noise goes away untill there isnt enough pressure being applied at the brakes. If I make a left turn it is a lot less severe. If I make a right turn it feels like my car is going to break into a million pieces.
Is my car driveable for the time being? Or is this one of those "fix this now or youre probably dead" kind of things.
Thanks in advance for any help.
Old Oct 21, 2006 | 05:27 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Sounds like it might be your front swaybar endlinks.
Old Oct 21, 2006 | 09:06 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
The part you are describing sounds like an endlink. They can make alot of noise if they are broke or loose.
Old Oct 22, 2006 | 02:03 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
I'm a *insert insulting term relating to intelligence*
Lug nuts were loose on my drivers tire
Thank you though.
Old Oct 22, 2006 | 02:05 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I've done that before in a different car. Something you'll only do once.
Old Oct 22, 2006 | 05:07 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Its bad enough that it happened once, you are 100% right.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
