Dropping just the front...Advise, please
Old Oct 25, 2006 | 07:51 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I am wanting to drop just the front of my car, by 1 inch....Anyone done this??? If so, pro's???? con's???? Would this alter steering geometry in a bad way???? Thanks for your input guys.....Tom...
Old Oct 26, 2006 | 08:37 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I'm in the same boat, except that 1" would be about the minimum, I'd prefer 1.5", maybe even 2". (I've got a fairly noticeable wheel gap that I'd really like to close, plus it would be better in an aerodynamic sense.)
Until seeing this thread, I figured that the only way to close the gap would be to cut the coils, but now I'm going to see if that chart might have something that'll work - that's gotta be better than screwing the spring rate up by cutting the springs...
If I don't see anything there, I'll contact a few of the spring mfr's, & see what they suggest.
Old Oct 26, 2006 | 08:54 AM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
eibach has springs for both 1 an 2 inch im running 2 inch its a rough ride and you will have to deal with alittle more bump steer but youll giggle like a little kid on the off ramps when tryin to keep your head off the glass dont bother cutting they are 20 plus years old an wore out
Old Oct 27, 2006 | 07:27 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
well thanks for the replys...How bout the steering geometry tho????????????
Old Oct 27, 2006 | 07:33 AM
sprojam's Avatar
Car: 86 Z-28
spoon makes a part to help correct the bump steer issue for aggressive street driving i think it does a great job although at the race track you will have to dig deeper it is something that all third gens have from the start or any that i have drove. like i said though i started like you wanting the look and just keep getting deeper an deeper lol
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
