Define WS6 Suspension, need to swap parts...
Old Nov 4, 2006 | 01:26 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
I have a 1987 trans am WS6 parts car, motor/tranny gone but was a 305 tpi...
HAs the big sway bars, and what not...
I have my 1990 RS that really badly needs its upgrade... So what do i pull exactly?
Sway bars, of coarse...
Springs, they sag but are much firmer...
What else?
I've heard the WS6 or whatever had a quick ratio steering box, true or not?
what can i pull off for maximum gain, without spending an extra penny, i already have a set or KYB GR2 shocks and struts waiting to be installed...
Old Nov 4, 2006 | 02:23 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
The brace that bolts where the front sway bar is. Dont forget that.
Old Nov 5, 2006 | 10:06 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I dont think a WS6 Firebird comes stock with the wonder brace under the front sway bar. I believe that Iroc's are the only ones that come equipped with the brace from the factory.
Old Nov 5, 2006 | 10:35 AM
bfox88's Avatar
Car: 90 IROC-Z
how much of a difference is there between IROC suspension and WS6. and what are the differences? i've been wondering this for awhile now.
Old Nov 10, 2006 | 12:33 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
me as well... i was under the assumption WS6 suspension was a better upgrade then IROC...
Old Nov 10, 2006 | 10:16 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
it is. the spring rate is firmer, and the sway bars are the same sizes, but sometimes bigger on the WS6. The steering gear on the WS6 is quicker, too, only 2-1/2 turns lock to lock. I'd grab the box, the bars, and the springs, and I'd see if the rear end is better than what you have. if so, keep it at least for a spare, if not for replacement.
the thing is, they never put the IROC wonderbar on the WS6. but for $45 from Lon at TDS, you too can have one.
Old Nov 12, 2006 | 10:25 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
ok so springs, sway bars, gear box... rear end sucked so no...
the new rear sucks for drum brakes... but i'll deal, the old 9 bolt was a POS....
Old Nov 12, 2006 | 10:41 PM
Car: 1982 Trans Am
Engine: 383 chevy
so i guess i don't understand. do you like the rear in the donor, or no? so far your list is good.
Old Nov 27, 2006 | 07:41 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I also, found a ws6 car, and would like to know more about the steering box, how would swapping that on my 89 RS affect driving????? Thanks, Tom
customblackbird
Aug 15, 2021 10:16 PM
E Rod
Aug 28, 2015 05:17 AM
cam-mike
Aug 24, 2015 07:23 AM
