New Type LCA Bushings, what you think?
Old Nov 23, 2006 | 06:14 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
http://www.hotpart.com/index.php?p=show&id=10
Old Nov 23, 2006 | 06:31 PM
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
Wow thats pretty awesome. Kinda getting the up side of spherical rod ends, with the isolation qualitys of a rubber type. Can't wait to see how thes work out. Allthough it dosent look like it has all that much room to articulate.
Old Nov 24, 2006 | 01:26 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I see that doing nothing but giving little more room for grease. From the other pic on the site looks like the 2 side bushings are still holding the sleave still tight, even if there was room for it to move I see that little rubber ball squishing pretty easy under load.
Edit: I see they are using softer rubber for the outer cups, maybe this idea might work out if the inner ball could hold up.
Old Nov 24, 2006 | 06:52 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
MM has been making something very similar for mustangs for years, I'm not sure how far they'll get with their patent. These bushings won't completely remove bind like they say, but it is a giant step in the right direction.
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
