Strut tower brace for TPI Firebirds
Old Nov 25, 2006 | 10:35 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Anyone know who makes one that actually fits AND clears the stock hood? I tried to get an Edelbrock 3 point to fit and even with the crossbar sitting on top of the TPI it still kept the hood from closing. I'd like a 3 point but at this point I'm considering something custom fabbed. Maybe something like the Hotchkis piece for V6 and SS Camaros that connects the towers to the cowl but doesn't cross over the intake until almost at the cowl area. Any thoughts?
Old Nov 26, 2006 | 01:09 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
A fellow NorCal member has a BMR, seems to fit fine
Old Nov 26, 2006 | 11:18 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I know the firebirds have a lower hood line.
Extreem...but..Maybe you could notch the brace just over the tpi plenum to drop it down some. A 1/4 might be all you need and still keep the strength of it.
Try pulling the brace forward on the strut towers as far as you can. the plenum slopes down on tb side you can drop it down more the closer to the tb you get. But you can only go so far.
Maybe get rid of the under hood insulation if you still have it. Run the cowl braces under the tower brace. You can even file the bolt heads if needed.
It fit fine on my camaro even with the SuperRam with a little adjusting.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
