Noob Question: How important is a good Suspension system?!
Old Dec 5, 2006 | 02:51 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
My cousin just bought a 87 GTA, and it has the nice 350, and all performance suspension.
What does a good suspension do over a stock one?
I have my camaro, and All I think about is more HP, but maybe a good suspension system is the way to go... are there any good/cheap/must have upgrades I should have?
-Thanks
Old Dec 5, 2006 | 03:38 PM
Shagwell's Avatar
Car: projects.......
More power means nothing if you can't put it to the ground.
These car's don't hook well with stock power-plants. Anything hi-po is mute without some traction mods. Especially since these cars are unibody and flex A LOT. Too many of them have the roof cracked from stock power plants alone.....
Old Dec 5, 2006 | 03:46 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
So what suspension mods are a must?
Old Dec 5, 2006 | 04:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
subframe connectors
steering brace (aka Wonderbar)
Strut Brace
working shocks/struts
good springs (stock are fine as long as they aren't worn out)
Old Dec 5, 2006 | 07:36 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Better lower control arms and
lower control arm relocation brackets.
Old Dec 5, 2006 | 08:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, I think everyone on these boards can agree that SFC's should be first and foremost.
Now, this question is asked about weekly, so dig through some old posts, you'll find more pictures, explanations why, pricing, part #'s etc etc, more so then you'd hope to get in replies
I did slightly better than stock parts, moog 5664 springs, cc635 in rear, KYB gas a just rear shocks, GR2's in front, poly bushings everywhere, and boxed LCA and panhard. With a SFC's, this thing is like its on rails. It's night and day compared to a stock 3rd gen, makes this thing feel like a race car. Closest i've ever been, at least
This cost me ~$1000, and that's replacing basically everything. You can go cheaper in the good 'ol US of A, but even slightly better than stock (like what i've done), is going to feel INCREDIBLE, especially if you're comparing it to 20yr old V6 suspension. Yours isn't that hurtin', so i'd say you should go even better, like the Konis, things like that.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 25, 2015 07:34 PM
