thunk/knock from rear driver side
Old Dec 7, 2006 | 02:44 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Whenever i hit a small bump say, leaving my driveway to enter the road, I can hear an audible thunk from what sounds like just below the compartment in the hatch on the drivers side rear. As far as i know nothing is loose as i have been under the car about 4 times this summer. Is this the sign of a failing shock or something?
Old Dec 7, 2006 | 03:15 PM
Stevo's Avatar
Car: Pair of 92 Z28s
ya perhaps the bushing on the top or bottom of shock has deteriated. Pull the carpet some just to make sure it didnt actually crack or damage the floorboard. But you are sure all of your bushings are in your sway bars, lower control arms, panhard all that stuff right?
Old Dec 7, 2006 | 03:47 PM
ezliving4ume's Avatar
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
Old Dec 7, 2006 | 04:55 PM
draco's Avatar
Engine: 5.0l TBI
It should be, I'll double check when I hang my exhaust up, thanks guys
Old Dec 7, 2006 | 07:18 PM
redlsone's Avatar
I have the same thing and just had new shocks and stuts put in. Its only on the left rear.
Old Dec 7, 2006 | 07:35 PM
89blues's Avatar
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
i've been trying to figure this noise out forever, I put new shocks and struts on and sounds like a knock, whenever going up or down a driveway from the rear somewhere
Old Dec 11, 2006 | 02:08 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
If all your bushings check out...
My 3" exhaust will occasionaly thunk the body on harder bumps. There is a spot where the coating has rubbed off and started some rust.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
