how do these wheels specs work out
Old Dec 14, 2006 | 08:53 AM
BOTTLEDZ28's Avatar
Transmission: A4
Do these wheel specs look good? I plan on adding theC5 brakes up front which will push the wheels out another 1/4" .
18x9 with 6.00 bs and +25 offset,
18x10 with 6.00 bs and + 13 offset
these specs where emailed to me from newstalgiawheel
for the junkyard dog wheels
Old Dec 14, 2006 | 06:23 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
spacers...
Old Dec 14, 2006 | 09:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya maybe a 1/4" spacers at the most on the front
Old Dec 15, 2006 | 12:15 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Minimum billet spacer size is 1.25 inch. 0.75inch if the wheels have recessed spaces between where the studs go. After that it's slip on spacer, and 1/4" is pushing it with those.
Offset basically has to be right on, or way off.
Old Dec 15, 2006 | 08:16 AM
BOTTLEDZ28's Avatar
Transmission: A4
well Im not sure if the offset can change on these wheels. I will have to call them and see what they say
Old Dec 15, 2006 | 11:30 AM
Ucantcme57's Avatar
What should I do with 18" rim, My rear is a 97 camaro. I don't mind dish in the rear and I want to put like 315's or 335's in the rear and 275's up front.. What should I order for my rims?
Old Dec 15, 2006 | 11:48 AM
BOTTLEDZ28's Avatar
Transmission: A4
well you could order wheel with a 4th gen spec for the rear and a 3rd gen spec for the front but your gonna end up with a depper dish on the front wheels. Your 4th gen rear is wider so now you have lost any possibility of getting deep dish wheels for the rear. This was my problem and now Iam switching back to a 3rd gen rear
Old Dec 15, 2006 | 06:07 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
maybe i misread your post but you can get 1" thick adapters(spacers)...the only thing that is technically SAFE to use on cars...a 1/4" spacer is not very safe at all and you run a good chance of having a wheel come off
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
milk
Aug 10, 2015 06:26 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
