sfc
Old Dec 19, 2006 | 11:38 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
sfc
hi all just wanted to know if this Competition Engineering Weld-On Subframe Connectors form summit was worth the money or are there better ones is there any other parts to consider changing
Old Dec 19, 2006 | 12:14 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
comp engineering are the WORSE ones on the market.
they are basicly straight bars.. you cut your floorpan for them to fit.
everyone else has ones that bolt up under the floor...
a basic search on here will provide you with more then enough info to decide what works for you.... but i just wanted to be sure you didnt order the comp engineering ones.
Old Dec 19, 2006 | 12:22 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
thanks probaly go with spohn then weres the best place to buy them as would need to ship to the uk
Old Dec 19, 2006 | 12:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
unless the place you order them from has them in stock (very unlikely) they will be drop shipped directly from spohn.
i do have a hookup for spohn parts, but im not sure if he ships out of the country... i'll send you a PM.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Aftermarket Product Review
Apr 28, 2001 05:02 AM
