How should sub frame connectors be installed???
Old Dec 20, 2006 | 03:19 PM
p.haze92's Avatar
Just curious on what type of rack sub frame connectors should be installed/welded on. A rack where you drive the car up on so the suspension is loaded or will a rack that lifts on the frame to allow the suspension to sag. About to install mine and wondered if it mattered??
Thanks in advance.
Old Dec 20, 2006 | 03:31 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
SFC need to be installed with the suspension loaded. A drive on rack is good. One that lifts on the frame is not keeping the suspension loaded plus it may get in the way of installing the SFC.
Old Dec 20, 2006 | 03:47 PM
Doesn't matter if the suspension is "loaded" or not.
The important thing is that the chassis is STRAIGHT.
I had mine done on a race car jig. Bolted it down to a metal plate about ¾" thick. No suspension was even installed on it at the time.
Another good way is to do it at a frame shop, after having the frame pulled to its exact specs, and held firmly in place there.
Old Dec 23, 2006 | 04:02 AM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
About how much did that cost? Having the frame aligned and sfc installed?
Old Dec 23, 2006 | 12:29 PM
It was free. Good friend from high school days. Got it done while doing paint & body work, so the whole car was in little pieces already.
Probably would have been $200-300 if I had just hauled the stripped chassis to a race car shop and paid like normal people do.
Old Jan 1, 2007 | 06:02 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Hahahaahha, normal people huh???????????
Old Jul 27, 2007 | 11:49 PM
SageMoonblade's Avatar
Re: How should sub frame connectors be installed???
I am planning on getting a set of SFC's but I have an issue. I know for a fact that my car is sagging abit. What can I do, WITHOUT taking it to a shop to tell how bad it is and get it back into shape to put the connectors in?
Old Jul 28, 2007 | 01:57 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
doors sagging has nothing to do with the chassis really, it's more the hinges being worn out and needing replacement.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
TheJoeY88
Dec 31, 2016 07:30 PM
toronto formula
Nov 10, 2015 06:17 AM
djmarch
Aug 19, 2015 12:07 PM
