O'Reillys Steering Box question
Old Dec 22, 2006 | 01:21 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
At O'Reillys they show 2 steering boxes for our cars..They have one for the soft ride suspntion, and one for the non soft ride suspension....My question is, if you buy the non soft ride box, will it be a WS6, or IROC, or Z-28 Box...In other words will it be the fast ratio box??? They are 128 dollars...Has anyone had any experiance with these replacement boxes???? If not do any of the other parts houses have the fast ratio box...I talked to the manager at the store, and he was not really sure...I want to make sure if I upgrade my box, I get the good one...Ideas anyone?????? Thanks alot, Tom
Old Dec 22, 2006 | 02:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i bought one from advance autoparts one time..
i just made sure it was for a car that was supposed to have that option... and the box i got was a quick ratio 12:1 box.
Old Dec 22, 2006 | 03:05 PM
Ed Z28 350's Avatar
They are most likely using Cardone as their supplier. Cardone only lists 2 boxes for our cars. They should list three. The fast ratio box comes in two flavors. One has larger internal stops designed for use with cars that came with 16" wheels from the factory. It has 2.25 turns lock to the lock. The other fast ratio box has 2.5 turns lock to lock. 16" factory wheels / tires will likely rub with the wrong box.
Old Dec 22, 2006 | 08:24 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Well, I have 17's on it now, and with the stock box I rub just a tad....Thanks guys...
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
