Has anybody put 4th gen Koni Yellows on their 3rd gen?
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Has anybody put rear 4th gen Koni Yellows on their 3rd gen?
They look like there easier to adjust than the 3rd gen yellow.
Whats the difference in the way thee two would feel?
btw: I'm just askn about the rears, I know the fronts don't fit
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Far as I can tell, the fronts are physically impossible to put on a 3rd. And the rears are exactly the same.
I thought that 4th gen rear shocks where the same as 3rd gen physically? I want to know if anybody has done it, or if the 4th gen ones have different valving tht wont work good on a 3rd gen. Joined: Oct 2006
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I think Dale said the rears WILL fit the fronts will not.
Engine: 350 S-TPI
I was pretty sure that they will fit. I'm really interested in the ride and handling qualities. Anybody try them, or is there a reason why people don't use them.
1992rs/ss
16
Jan 28, 2016 09:58 PM
