Replacing std. front sway bar with WS6 bar. Diff bushings but same brackets?
Old Jan 19, 2007 | 05:30 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a V6 car I converted to V8 and put WS6 springs all the way around. I now am installing the WS6 sway bars. I have only a front V6 sway bar on the car now. I have the rubber bushings for the front WS6 bar. Will the WS6 bushings for the big front bar fit inside the V6 sway bar bushing clamps? I assume so but just wanted to check.
Also, how is a rear sway bar bracket mounted, and where does it mount? The car came from the factory with no rear bare. Do I have to drill/tap holes for adding the rear bar, or are holes already there? A photo would be awesome if someone can show me where the rear sway bar brackets mount.
Old Jan 19, 2007 | 10:10 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The front and rear swau bar bushing brackets are all the same regardless of the size of the stock style bushing. Yes the holes for the rear end link mounting brackets are already there and are threaded. I have the brackets in question listed on my web site if you aren't yet aware of what they look like.
Lon
Old Jan 19, 2007 | 10:29 PM
Car: 2000 BMW M5
Thanks! I didn't even realize I needed the end link brackets. I'll order them from you. Where do the sway bar brackets themselves attach to the body, and are those holes already there too?
Old Jan 20, 2007 | 01:20 AM
lonsal's Avatar
The rear sway bars are attached at two points, the sway bar bushings and the end links. The end links mount to the end link brackets which are bolted to the body.
Lon
Old Jan 20, 2007 | 09:54 AM
Car: 2000 BMW M5
Okay, the end links bolt to the body on one end. Where do the sway bar brackets bolt to?
Old Jan 20, 2007 | 05:40 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The links bolt to a clamshell piece that attaches to the chassis. The sway bar mounts to the rear end housing with a u-bolt arrangement.
Check your pms.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Amillionoh7
Aug 7, 2015 01:24 PM
