ls1 fronts/lt1 rears what size drag rims
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
so i have ls1 front brake conversion. and i have lt1 rears for my strange 12 bolt rear(wish i could of run ls1's) anyways i think the smallest rim i can fit is a 16 i may be wrong.
so what size front skinny?
so what size rear rim(that would give me the biggest tire)?
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
I can relate what fits on 4th gens if that helps.
rear LT1 15x10 w/ 7.5" BS. Weld prostars & draglites fit with minor grinding of the caliper fins. Bogarts fit without grinding, but plan on $450/wheel.
front LS1, same brands as above, 15 x 3.5" w/ 1.75" BS. Using a 5/16" spacer with the Weld wheels to clear caliper.
Hope this helps.
Hope this helps.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 15 x 3-1/2" rim won't fit over the LS1 caliper even with a spacer. You're going to need a 16" front rim to clear the caliper.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
You better check your info......
They do fit. ProStars are on the front of my car with LS1 brakes.
If you do not believe me, do a search on LS1 tech. You will find a few hundred posts confirming this.
Lonnie
Lonnie
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
