What size tires are these?
Old Jan 22, 2007 | 12:34 AM
syko's Avatar
Hi all,
I saw a picture of this Camaro on Wikipedia... Here's the link:
http://en.wikipedia.org/wiki/Image:C...iew-sstvwf.JPG
I was wondering, what size tires are those?? Those look really nice and I want to do the same thing to my car.
---EDIT: I'm interested in how wide the tires look.
Old Jan 22, 2007 | 01:37 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Hmm. Its hard to see how wide the tires are in that pic. I loaded it up into photoshop and messed around with the brightness and contrast so I could see the tires better, and they appear to be stock sized, just sticking out a bit. Maybe spacers on all 4, or a 4th gen rear and spacers in the front? Hard to tell. Maybe the fronts are stock now that I look at it again...
You might try emailing the owner. His information is listed on that site.
Old Jan 22, 2007 | 05:43 PM
marroman's Avatar
Car: 1987 Z28 Camaro
Engine: 350 small-block
Ya i think stock tires with spacers.
Old Jan 22, 2007 | 05:51 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
the rears look a little wider than stock.. it has more of a bulge that the fronts.. 255's maybe??
Old Jan 22, 2007 | 10:53 PM
syko's Avatar
So if it's spacers, what size should I get?
Old Jan 22, 2007 | 11:15 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
You can get 235/60/15 in the front and 255/60/15 in the rear and it will look similar to that except better because the rear tire is actually that wide to the body without the spacer. Looks amazing from behind. Sorry these couldnt be better they were stills taken from a video. I'll look for a better picture of just the tire profile, but I'm sure you get the idea anyhow.
Old Jan 24, 2007 | 01:23 AM
syko's Avatar
What size spacers do you guys think that is then?
Old Jan 26, 2007 | 02:42 PM
syko's Avatar
Anyone? And can I purchase spacers at a store? I'd prefer not to order online.
I contacted the owner and it turns out that he's not the actual owner, so that's a dead end.
Old Jan 26, 2007 | 03:02 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
looks like maybe some 225's
Old Jan 27, 2007 | 07:58 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Don't screw around with spacers, the slip on kind are not safe in anything past a 1/4" and you can't get a bolt on spacer in less than 1". On top of that bolt on spacers cost as much as a cheap set of wider 15" wheels.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
