Mobile One grease with poly bushings?
Old Jan 27, 2007 | 12:23 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Can I use Mobile one synthetic grease or do I have to use the "white" stuff? Also, when installing, should i put grease on every surface of the bushing, including the sides, and how much?
I'm mainly concerned with LCAs, sway bar, and panhard bar bushings.
Old Jan 27, 2007 | 11:46 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, there's always a bit of debate. I think the final answer was that any grease will do, but that sticky white stuff lasts longer. I think the mobil 1 synthetic is used commonly on this board.
Grease any poly-metal area. Anytime poly touches metal, goop it with grease. So on the sides of your LCA's, where it'll rub the brackets on the axle, and frame side, GOOP IT UP. Same with panhard, etc. Between the bushing and shell, it should be greased from factory, not that you could actually grease it yourself, even if you wanted to.
I think 83_Crossfire_TA modified his to have a grease channel, and added grease nipples.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
school boy
Oct 22, 2015 11:47 AM
loud91rs
Oct 5, 2015 10:05 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
