Lowering Spring not sitting right?
Old Jan 29, 2007 | 08:54 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I put the Pro-kit on my car over the weekend. When I was doing the driver's side front spring, I couldn't get it to "settle" properly in the top spring perch. I figured that when it was all put together, it would 'pop' into place. When I got everything buttoned up, the pass. side had dropped a 1/4 inch, and the drivers side was up about an inch over stock.
My question is, will this spring 'pop' into place if I drive the car? Will driving the car hurt anything? (I dont really care about tires, I have a new set to go on)
I havn't checked since it sat over night, maybe it settled on it's own?
Any thoughts / comments?
Thanks.
Old Jan 29, 2007 | 11:14 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
umm why didnt you put it in correctly? the bottom coil has to cover one of the holes in the a-arm but not the other, i just did this it was easy as pie. it will not pop in to place.
Old Jan 29, 2007 | 11:40 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You should be able to look up into the top spring perch from below and verify whether the spring is seated correctly. If it's seated correctly and you haven't yet moved the vehicle the driver's side may be canted up on the control arm (the arms swing in when lifted). Rolling it a few yards will allow it to settle.
If it's not seated correctly, try again.
Old Jan 29, 2007 | 12:19 PM
KZad's Avatar
I had been in the garage working for hours getting strut bolts out I really just wanted get it all put together. I had hoped it would pop back in, but I guess it won't. As naf stated, I can look up there and see that it's not quite in the top perch correctly. The bottom of the spring is correctly between the two holes in the A-arm.
Oh well, I guess I'll be tearing it down again this weekend.
Old Jan 29, 2007 | 12:44 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
here's what I did..I just redid mine over the weekend...your lowing springs should be smaller than stock..so you wont need a spring compressor...
before you set the spring in, tape the rubber to the top of the spring so it doesnt move when putting it it...then put some oil on it to make is slippery.(not alot) just wipe some on there....I also put some on the bottom part of the spring so it would make it easier to move....
then set the spring in the top and align where you want to put it on the A-Arm...then you should be able to push it onto the A-arm, bend the a-arm back futher f you got to..it will come out of the cup at the top alittle but once you have pressure on the spring from jacking the A-arm up...just take a rubber hammer and pop it back into place....
worked for me
I dont care if its not the correct way to do it..but mine are in and im happy!
Old Jan 29, 2007 | 03:21 PM
KZad's Avatar
I did the tape thing with the rubber bushing up top, the oil is an interesting idea. Maybe I'll try that. Looks like I'll be working on this wednesday night. I'll let you all know how I make out.
Any other hints or tips are surely welcomed.
Old Feb 1, 2007 | 12:20 PM
KZad's Avatar
All fixed. The drivers side front was not in the top perch at all. I tore it down and re-did everything, and now both front springs sit the same height. Now I just need an adjustable panhard bar to set the rear end back in alignment. Anyone have one laying around?
Old Feb 23, 2007 | 01:29 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
So how do you like the springs? Any pics?
Old Feb 23, 2007 | 03:57 PM
KZad's Avatar
Nah, no pics yet (maybe when it gets a bit warmer) but I absolutely love them. Beautiful stance, and a great ride. I have all the numbers written down somewhere, but I think the front dropped about an inch and the rears closer to a half an inch right after the install. One of these days I'll take a final measurements and post up everything with pictures.
Old Feb 23, 2007 | 06:14 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Glad you like'em. I loved them when they were on my car.
Old Feb 24, 2007 | 11:49 AM
KZad's Avatar
Did you end up going with the sportlines or something else? Got any pics of yours - how much lower is it?
Old Feb 24, 2007 | 02:23 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I went with Sportlines. I'd say it lowered it about another 3/4" - to an 1"
Old Feb 25, 2007 | 03:00 PM
KZad's Avatar
Looks great. How's the ride compared to the pro-kit?
Old Feb 25, 2007 | 08:27 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I thought it rode the same as the prokit. I only had about a 1/2 hour of seat time in it beween getting it back on the ground and selling it though.
Old Apr 23, 2007 | 09:23 AM
KZad's Avatar
Re: Lowering Spring not sitting right?
Originally Posted by KZad
Nah, no pics yet (maybe when it gets a bit warmer) ...
Well it was beautiful this weekend, so I snapped a few pics. I like this one the best. Lemme know what you think.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 26, 2015 03:32 PM
