Would this, fit that year?
Old Feb 2, 2007 | 08:43 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Hi guys!
I got a buddy with a 1982 Iron Duke, who's steering box needs replacing, I went to pep boys and thier computers come up with the same steering box as a 1990-92 (actually 1982-1992) I took a look at the PEP BOYS reman gear box and it looks like my 91's RS. I was wondering if there would be any incompatibility if I install this reman gear box into the 1982, should it fit in correctly and work correctly? the 1982's gear box looks a bit different but the design may have changed in the early 90s? Any help would be great thanks
The Steering ratio of the PEP BOYS reman gear box is 3.5 bolt housing cover std steering
Old Feb 3, 2007 | 06:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's some general info as an FYI (I'd like to give credit, but I don't recall where I found the info):
• “WS” – 1982-1992 Camaro – 12.7:1 ratio (just like your Z/28, this may be the box that you Z originally had.
• “XH” – 1985-1992 Camaro – 12.7:1 ratio (this box was also installed on Z/28’s and other high performance Camaros; it has slightly more steering effort required than the WS box.) NOTE – I believe this box was used on cars originally equipped with 16” wheels
• “WN” – 1982-1985 Camaro – 14.1 ratio
• “WP” – 1982-1985 Camaro – 13:1-15:1 variable ratio (used in Berlinettas, least steering effort required of all third gen. Camaro steering boxes)
• “JL” – 1986-1992 Camaro – 14.1 ratio (base Camaro steering box)
JamesC
Old Feb 3, 2007 | 07:17 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
but it still can be done? right?
Old Feb 3, 2007 | 10:17 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
off topic but.... i take it you didnt sell that lt1?? if its goin in can i see some pics?
Old Feb 4, 2007 | 01:10 AM
CrazyHawaiian's Avatar
Car: too many ...
Does the 82 have power steering or manual steering?
Old Feb 4, 2007 | 04:50 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Power Steering.
Will the wheels rub? I think theyre 15 inch.
Frozer!!!
Jan 19, 2024 04:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
TheJoeY88
Aug 13, 2015 06:51 PM
3rdgenparts
Aug 5, 2015 11:57 PM
