fattest tires 4 16/8 gta rims??????
Old Feb 8, 2007 | 01:12 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
i just want to know whats the widest tread anybody has squeezed on an 16 inch stock gta rim? looking to go wide on my car and lower with the eibach kit i think its 1/ 1/2 inches down?
Old Feb 8, 2007 | 02:21 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Widest Tire
After doing alot of research for my 87 Iroc and tire width
I found the widest tire out there for my 16'' rims was the
BF G-Force Sport 255-50-16. 10.2 section width and
almost 10" treadwidth. The Dunlop SP Sport 8000 is
also close to this.
Had ordered the BFG 255-50-16 Drag Radial and Tire Discount nice enough to let me switch at no cost. Do
more touring than racing and tread wear a factor.
BFG KDWs 245-50-16 for the front as the 255s to big
and rub in a turn. Car also lowered.
Don't know how the 3rd Gen Firebirds fender well lips
differ from the Camaros.
HTH
Later
Irocing
Old Feb 8, 2007 | 02:51 PM
Shagwell's Avatar
Car: projects.......
255's in the front will rub slightly at full lock. - 255/50/16 is the widest tire made in a 16" size. It is also the widest tire that will fit the wheel properly.
- You can get wider 16" sizes in specialty tires (like Hoosier's SCCA models), but for over $200 per tire and they'll last about 1000 miles.... BFG also makes a 295/50/16 Radial T/A, but they don't perform as well as even a half decent 255/50.
Old Feb 9, 2007 | 10:47 AM
OneMeanLG4's Avatar
Car: 85 Berlinetta
Engine: 305 LG4
Axle/Gears: 3.23 I think
I wouldn't recommend 295/50/16 unless your chenging your gears, your speedo will be off quite a bit. Theres almost a 2" difference in tire sizes. Remember 50 isn't sidewall height, its aspect ratio.
Old Feb 9, 2007 | 12:29 PM
Shagwell's Avatar
I wasn't reccomending them, I was saying that they exist, but suck. I also stated that a 255 is the widest that will properly fit the wheel.
- not trying to flame, just re-itterating what I said....
Old Feb 9, 2007 | 02:23 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I run 245/45r16 on my crosslaces. Ohtsu HS401G's. No rub. I also have the different offsets front/rear. If you go wider, would the tire may roll over making the car feel sloppy?
Old Feb 10, 2007 | 12:12 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I have Firehawk SZ50s on my GTA rims, 245/50/16s up front, & 255s in back. They are great for wet traction, very good performance when it's dry, & no, they don't "roll over" or feel mushy.
I highly recommend 'em.
Old Feb 14, 2007 | 02:42 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
i ran bfg 255/50/16 drag radials, and mickey tompson 26x11.5 et streets.
Old Feb 14, 2007 | 01:57 PM
Stephen's Avatar
Car: 87 GTA
According to tirerack.com, there is no Firehawk SZ50 (or SZ50 EP RFT), in anything less than a 17". Discontinued since you bought yours?
I have 245s on my GTA, and want wider ones for the rear too, but haven't found anything wider than the 255s, except the 295/50SR16 of the BFG Radial TA. I had those on my 92 RS, with the stock 16x8 wheels. I'm going to get them, after the xmas bills are paid off.
Old Feb 14, 2007 | 02:13 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
stephen, were did u get the sequential tail light kit. i need it!
Old Feb 14, 2007 | 02:30 PM
Stephen's Avatar
Car: 87 GTA
So as not to hi-jack the tire thread...
STS thread
Old Feb 14, 2007 | 11:25 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Firestone Firehawks SZ50 in our size has indeed been discontinued. I got a deal on a set of four from Tirerack when they were selling off the last of them. Think I paid
420 for a set of four shipped for what I believe was the best performance tire made in 245/50/16. Firestone wanted almost double that. They are still in storage ready to go.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
