View Poll Results: which is better
floor first
100.00%
sfc's first
0%
Voters: 1. You may not vote on this poll
looking at umi's sfc's but.....
Old Feb 11, 2007 | 11:49 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
I'm looking at umi's sfc's but should i do umi's and then the floors or floors then umi's
I'm thinking sfc's first that way the car has more support when they cut into the floors.
opinions welcome
Old Feb 11, 2007 | 11:57 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
The first thing that you need to do which either project is properly support the car. If you have access to a drive on lift, one that has the suspension loaded, use that to weld in the SFC's. You do not want to weld in the SFC's with the wheels off the ground. It would probably be easier to change out the floor with the SFC's out of the way. Yes they will give a bit more support to the car but if your changing the floor or sections of the floor you should have the car properly supported anyway.
My comment is to find some way to support the car in a few places before you cut the floor out. The best way is with the car supported on a frame jig like a good qualtity body shop has. This will reduce the body from getting twisted or welding in the new sectios of floor with something mis aligned.
Old Feb 12, 2007 | 09:23 AM
Car: 86 Z28
Axle/Gears: TBD
i will not be doing either of these. the sfc's will be installed by a local speed shop thats used to handling mostly f bodys both suspension/chassis wise aswell as tuning and engine mods/upgrades. they are a full service hipo shop.
the floors will be done by the guy that will be doing my bodywork and paint. he's been doing custom cars around 30 years and i've seen some of his floor replacements and he does a great job.
i'm just figuring who to drop the car off to first.
Old Feb 12, 2007 | 01:54 PM
Car: 86 Z28
Axle/Gears: TBD
anyone else?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
LT1Formula
Oct 8, 2015 08:34 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
luvofjah
Sep 10, 2015 10:41 AM
