oh shat, pretty mad
Old Feb 12, 2007 | 08:34 AM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
oh shat, pretty mad
well, the other night i was driving in the snow (17 only car) and slid into a curb at about 25 mph, i broke the front spindal, had the idler arms, tie rod endlinks, and ball joints replaced, the car still pulls to the right, which i think its just an alignment, but the steering feels loose, did i screw up the centerlink(which was replaced a week before)? and i went to my 215/65r15 snows and they suddenly are rubbing something, im not sure what, i havent had a shot to look? is it possible to have bent something so everything is now pushed further back? not to good with suspention parts. or were all wheels off set differnently and they are just rear wheels?
Old Feb 12, 2007 | 07:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
It could be several things, or a combo of things.
Someone here just weeks ago did a similar thing, and it moved his k-member over. You will have to loosen all that, slide it over.
Check to make sure you didnt bend the chassis, a-arm, upper mount, etc.
Have you taken it for an alignment since you fixed everything?
Old Feb 13, 2007 | 10:22 AM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
im taking it next week on my vacation because i go down to a friend in CT which is like 25 miles away
also would second gen wheels fit my car? i found a set of 15" cragers off of a 79 trans am and was wondering if the ywould fit
Old Feb 13, 2007 | 12:46 PM
emac2001's Avatar
Car: 86 z28
if im not mistaken those rims off the 79 should fit with no problem ive seen alot of people around put the wheels off a 3rd gen on 2nd gen so you should be good to go
Galaxie500XL
Feb 1, 2020 04:53 AM
MM2Robinson
Oct 1, 2017 09:16 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
ramicio
Sep 28, 2015 01:18 PM
Numbah-1
Brakes
Sep 21, 2015 05:18 AM
