NEED HELP ON BEST WHEEL AND TIRE SIZE!
Old Feb 16, 2007 | 12:30 PM
AWOROADDAWG's Avatar
Car: 1985 Z28 camaro
Axle/Gears: 4:10
Hi Im trying to figure out the best back spacing on my 85 camaro. i am wanting to run a 15x8 inch weld wheel on the back and i wanna get the best looking combo. and i wanna hav a nice size tire on the back too.With out it rubbing or sticking out of the fender well. If anyone could tell me the best amount of back spacing and the best tire size to run it would really mean alot. thanks, Adam
Old Feb 16, 2007 | 12:39 PM
LUVmy92's Avatar
Car: Camaro
5.5" back spacing will fit a 17x9.5 properly. Having gone with 17x9.5's I sometimes wish I went 18x9.5's instead but I am happy with what I got.
Old Feb 16, 2007 | 01:11 PM
Axle/Gears: 4:10
ya i was gonna run a set of 18x8 in iroc z wheels but i gotta stay within my college student budget. money is tite. i got enough money to buy a new set of 15x8 welds but im still tryin to figure out the best tire size without rubbing or stickin out the rear wells. thanks for the advise though, Adam
Old Feb 16, 2007 | 02:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
255/60 or 275/60 is sexy.
https://webdisk.ucalgary.ca/~jmknopp...t,%20may06.jpg
https://webdisk.ucalgary.ca/~jmknopp...th%20tires.jpg
Old Feb 16, 2007 | 02:32 PM
Axle/Gears: 4:10
with using either one of those tire set ups. do u think i could still lower my car 1.2 inches without a problem?
Old Mar 11, 2007 | 04:42 AM
83 Crossfire TA's Avatar
Yep… they will fit under a lowered car with the right offset… those 2nd gen wheels have 0 offset and they stick out a little, ½” offset in like stock 15” rims fits better.
255/60’s fit with either offset even with the car lowered _a lot_ (more then 2”), 275/60’s I rub a little on front of the inner fender (just barely enough that you will see where it rubs off the undercoat, but not enough to leave a mark on the tire. This is the spot that people talk about hammering with larger tires, just whack it a couple of times with a hammer and it’s fine. On 0 offset rims like in the pic I believe that you’ll have to roll the fender lips to prevent it from hitting with that tall a tire and shorter then stock ride height.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
